pinion angle shims and locator pin #1062588
08/24/11 10:17 PM
08/24/11 10:17 PM
Lancaster, Pennsylvania
Sweigart1022 Offline OP
when adding shims to change pinion angle....... what do you guys do or have done to the locating pin to get it to go up through the shim and into the spring perch
Re: pinion angle shims and locator pin [Re: Sweigart1022] #1062589
08/24/11 11:02 PM
08/24/11 11:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
the 1's i have used fit right on the pin....maybe you can take a measurement and open it up to fit without any problem..but i could be wrong..mike
Re: pinion angle shims and locator pin [Re: earthmover] #1062590
08/24/11 11:13 PM
08/24/11 11:13 PM
i need the pin to be longer sorry for the confusion
Re: pinion angle shims and locator pin [Re: Sweigart1022] #1062591
08/24/11 11:25 PM
08/24/11 11:25 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Driveline shops keep them in stock. I had bought some from a place in Baton Rouge, La. A place called Margot's.
They did driveshafts, rebuilt power brake boosters, and re arched leafsprings.
Summit and Jegs may have some to, you need to know the size. They are cut to fit, so if you added more leafs
Re: pinion angle shims and locator pin [Re: Sweigart1022] #1062592
08/25/11 01:18 AM
08/25/11 01:18 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I've run the bolt up from the bottom and used a 5/16 all thread connector nut, which is about 7/8" long to get the extra length to locate the axle.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
