Page 10 of 10 1 2 8 9 10
Re: New 512 stroker build, ZERO power! [Re: Cab_Burge] #1062520
10/05/11 02:53 PM
10/05/11 02:53 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey Cab, Thanks for the response! I'm using the Indy valley plate with their EZ heads. No "bath-tub" gasket. I ran a good bead of RTV along the ends and side rails after installing heads. Intake gaskets sealed fine too. Take care! Jeff
Re: New 512 stroker build, ZERO power! [Re: 1969RR] #1062521
10/05/11 11:53 PM
10/05/11 11:53 PM
It ain't that then is it The grey oil could be from water(condensation) Maybe not.
