Water restrictions in head gaskets? Opening them up?? #1062338
08/24/11 06:19 PM
08/24/11 06:19 PM
Ohio
3404 Offline OP
3404  Offline OP
Ohio
Anyone open up the water passages in head gaskets to allow more flow?
I have a Mopar Mega Block with Indy heads and Cometic gaskets that I'm putting back together and always wondered if opening up the top slots or putting a .125 hole in the bottom ports that are totally covered would help or make things worse..
Thoughts?
Re: Water restrictions in head gaskets? Opening them up?? [Re: 3404] #1062339
08/24/11 08:50 PM
08/24/11 08:50 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i asked cometic a few years ago about that. they told me to just put them on as is. i did use a film out silicone sealer around the oil & water holes. stay safe, seeya.
