Re: Hit oil pan on launch.
[Re: 340_Dart]
#1060818
08/24/11 07:28 AM
08/24/11 07:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Sounds like you need to raise the front end up a little or run a taller front tire or... Get a shallower oil pan...
Its a self shallowing pan if he does that any more put a taller tire on unless you have good reaction times now... if so either raise the body up or a shorter pan.... you could add a skid plate to the K member to protect it
[Re: Cuda367]
#1060820
08/24/11 12:31 PM
08/24/11 12:31 PM
Posts: 5,080 organ
maximum entropy
organ
how about making it so you don't have to get out of the throttle after launching?
[Re: MOPARCRAZY]
#1060822
08/24/11 01:09 PM
08/24/11 01:09 PM
Posts: 47 ohio
6440nssa
ohio
Y don't take the junk shocks off and put on a set you can adjust to a stiff setting so the shock controls the front end.
sean dornan
[Re: MOPARCRAZY]
#1060823
08/24/11 01:14 PM
08/24/11 01:14 PM
MR_P_BODY
I have a 69 Dart w/Indy 540 and a Milidon oil pan. I didnt launch straight and when I got out of the gas oil pan bottomed out on the track. Front wheels normally go up maybe a foot. I can turn it down but I am wondering if this is normal for an A body (I have v8 bars in it) or if I have front set wrong?
When you say they normally lift a foot.... how high did they lift when you bent the pan
[Re: MOPARCRAZY]
#1060825
08/24/11 01:50 PM
08/24/11 01:50 PM
MR_P_BODY
It went a little higher than normal, just not straight. Landed harder because of getting off the throttle. A couple good ideas given here. In order for me to take up the front any more I will have to raise the rear(not a big deal). I will lower the front and check the stops if I can do anything there. I am geting my converter adjusted and assuming that flashes where I want, I can then set the ladder bars for less air on launch. I see a lot of pics of wheels up launches and was curious if they ran into this. I will check my shocks as well.
What do you have for front shocks... they sounds like they are wasted if it can fall that easy... but I would raise the front some
[Re: dOc !]
#1060827
08/24/11 08:24 PM
08/24/11 08:24 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
A good pair of shocks will control the front from coming down to hard, ask me how I know, 3 pans in 3 weeks,. Put on some good 90/10's and you'll be OK
