Re: ?? would you port this intake or just run it??
[Re: mopar65]
#1060800
08/24/11 12:04 AM
08/24/11 12:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
It may not hurt much BUT I port all of my intakes to get the best I can... that shouldnt take you long at all to do that... once you get near with a burr then use tootsie rolls... they dont jump around like a burr... how is the intake to head match up
[Re: MR_P_BODY]
#1060801
08/24/11 02:54 PM
08/24/11 02:54 PM
As easy as this intake is to take on and off, I would run it as is and get a baseline. Then I would clean up the ports and run it again to see what the damage was. When someone on the Moparts board asks the same question you could have an expert opinion on the subject. You might even be able to get lucky and get in a heated debate about it.
[Re: mopar65]
#1060805
08/24/11 09:57 PM
08/24/11 09:57 PM
Posts: 7,506 Az
Crizila
Az
Porting and port matching are 2 different things. I would definitely port match it. No $, minimul time, and gotta be better, even if you can't / don't measure it.
Fastest 300
[Re: mopar65]
#1060807
08/24/11 10:43 PM
08/24/11 10:43 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is that what your car runs with the M1 ram in your sig? i would love to hear the results for a BATTLE OF THE RAMS
some say the Offy ram is even better than the weiand.(where is TJ Marcus)
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1060808
08/24/11 11:15 PM
08/24/11 11:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I have always heard the Weiand was tops Looking froward to the manifold shoot out Bobby Try flipping the top end to end and see if you get better runner alignment, I did Gonna have a little shoot out myself someday Ported Weiand X-Cellerator vs Ebrock Victor vs Weiand TR
[Re: roadhazard]
#1060809
08/24/11 11:24 PM
08/24/11 11:24 PM
Posts: 996 Queens, New York
Harley
Queens, New York
I didn’t go to the track but I can tell you this, I had taken my tunnel ram off and went back to my single four barrel. Well that lasted a couple of weeks and now the tunnel ram is back on and it not coming off again. The difference in torque is amazing. I think you are going to like the T/R a lot. Good luck with you test and keep us posted on your findings.
