#1060504 - 08/23/11 06:42 PM W5 cooling
emarine01 Offline
Loc: nc
Anyone got a good pic of a W5 cooling from the center plugs in the head? And did you see any temp drop or other gains?
#1060505 - 08/23/11 06:49 PM Re: W5 cooling [Re: emarine01]
MattW Offline
Loc: Ontario Canada
A while back Ryan built an R3 dyno mule and had cooling plumbing to the centre exhaust ON THE BLOCK and had a hard time cheaping it warm.IIRC
Maybe he will chim in?
You can go to Moparchats.com and read all about the stock and modified smallblock cooling from 40ford.
Apparently hot oil, cool block = max hp Matt
#1060506 - 08/23/11 08:01 PM Re: W5 cooling [Re: MattW]
charger410 Offline
Loc: australia
This is my set up. They just all run to a thermostat.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
#1060507 - 08/23/11 08:34 PM Re: W5 cooling [Re: charger410]
emarine01 Offline
Loc: nc
Was it worth the effort?
#1060508 - 08/23/11 08:56 PM Re: W5 cooling [Re: emarine01]
rickraw Offline
Loc: Ambridge, Pa.
i ran all 6 lines to a distubution box which holds a thermostate. 9 second street car, runs 170 down the road, will see 200 in traffic. heads only had 4 lines on it when i bought the car, center holes were plugged. passenger side head warped after i summer. all is good now. stay safe, seeya.
25,344 Registered Members
190,219 Topics
D100 Fenderwelll Headers
by 6pakdakota
06/21/18 01:35 AM
Silver Sport's T56 perfect fit kit shifter relocation
by 71_dramaqueen
06/21/18 01:27 AM
R/T rear valance brace, Challenger
by 71_dramaqueen
06/21/18 12:59 AM
WIW 1999 Ramburban
by dodgedon
06/21/18 12:23 AM
