W5 cooling #1060504
08/23/11 08:42 PM
08/23/11 08:42 PM
nc
E
emarine01 Offline OP
E
nc
Anyone got a good pic of a W5 cooling from the center plugs in the head? And did you see any temp drop or other gains?
Re: W5 cooling [Re: emarine01] #1060505
08/23/11 08:49 PM
08/23/11 08:49 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
A while back Ryan built an R3 dyno mule and had cooling plumbing to the centre exhaust ON THE BLOCK and had a hard time cheaping it warm.IIRC
Maybe he will chim in?
You can go to Moparchats.com and read all about the stock and modified smallblock cooling from 40ford.
Apparently hot oil, cool block = max hp Matt
Re: W5 cooling [Re: MattW] #1060506
08/23/11 10:01 PM
08/23/11 10:01 PM
australia
charger410 Offline
charger410  Offline
australia
This is my set up. They just all run to a thermostat.
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: W5 cooling [Re: charger410] #1060507
08/23/11 10:34 PM
08/23/11 10:34 PM
nc
E
E
nc
Was it worth the effort?
Re: W5 cooling [Re: emarine01] #1060508
08/23/11 10:56 PM
08/23/11 10:56 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i ran all 6 lines to a distubution box which holds a thermostate. 9 second street car, runs 170 down the road, will see 200 in traffic. heads only had 4 lines on it when i bought the car, center holes were plugged. passenger side head warped after i summer. all is good now. stay safe, seeya.
