Engin diseling! #1060362
08/23/11 04:43 PM
08/23/11 04:43 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
When starting engine after its been sitting over winter everything went OK. Exept the back ports of the Dominator flooded.
But when shutting down,the engine kept on running, had to cut fuel before it died! Everything is same as last season exept that engine and trans has been out of the chassi.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Engin diseling! [Re: fed] #1060363
08/23/11 04:46 PM
08/23/11 04:46 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
if you are running an MSD ignition it may just be the ignitionsystem causing it. there is a description of how to fix it with a diod in the instructions
Re: Engin diseling! [Re: 1Fast340] #1060364
08/23/11 04:54 PM
08/23/11 04:54 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
It was setup exactly the same last season havent touch the distributor
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Engin diseling! [Re: fed] #1060365
08/23/11 04:56 PM
08/23/11 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is the idle RPM higher than before and is it running
FAT... either one or both will cause that.... also
if you pull it into gear it will kill the engine unless
its a super loose converter
Re: Engin diseling! [Re: MR_P_BODY] #1060366
08/23/11 05:09 PM
08/23/11 05:09 PM
BTW, is this the same fuel in the tank as last year when you shut it off the last time If so try changing it to new fuel
Re: Engin diseling! [Re: Cab_Burge] #1060367
08/23/11 05:13 PM
08/23/11 05:13 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
New fuel,bought to day!
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: Engin diseling! [Re: fed] #1060368
08/23/11 05:28 PM
08/23/11 05:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was the engine still trying to flood... varnish on
the needle and seats
Re: Engin diseling! [Re: MR_P_BODY] #1060369
08/23/11 05:31 PM
08/23/11 05:31 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
I will have to check the carb tomorrow.
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
