PRW water pump works GREAT!! #1060324
08/23/11 02:15 PM
08/23/11 02:15 PM
Finally a HUSKER again
Moparnut426 Offline OP
The 408 in the Demon always wanted to creep up past the 200 degree mark, even on long drives down the highway, I have a mechanical fan, shroud, and a large BeeCool radiator. I tried everything, had dual electric fans, worse heating with those, then i swapped the lower march pulley to a larger diameter, and that helpped a little bit. Well i found this PRW water pump that guarenteed I would have no more issues. Well I am happy. Its has a 160 stat inn it, and with the air temp at 92-95 degrees, and HIGH humidity idleing around town the thing stays pretty darn rock steady at 150-165ish depending on my foot, and the speed. I let it heat soak, and drove it a bit harder, and idled around town some more, it got to 170 once, and came right down and that was when i idled it into the shop, and revved it up a bit just sitting there.
Very happy with the results. the pump has a design that pushes the pump housing back into the timming cover, and the pulley is platted off in design to keep any cavitation from starting.
Heres a linky.
http://www.prwonlinestore.com/1431800.aspx
Kasey
Re: PRW water pump works GREAT!! [Re: Moparnut426] #1060325
08/23/11 02:26 PM
08/23/11 02:26 PM
Az
Crizila Offline
Crizila  Offline
Az
Proof in the pudding that you can't have too much flow through the rad. Nice lookin pump. Wish they had shown a back side view.
Fastest 300
Re: PRW water pump works GREAT!! [Re: Crizila] #1060326
08/23/11 02:32 PM
08/23/11 02:32 PM
Im sorry, I really should have taken a picture of the back side. I may have it on my phone, but its been acting up. Ill look and see.
Kasey
Re: PRW water pump works GREAT!! [Re: Moparnut426] #1060327
08/23/11 06:49 PM
08/23/11 06:49 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Kasey
There's a good write up at monarchs.com. by 40ford about smallblock cooling. Basically said the the stock pump and housing start to cavitate at a certain rpm and hardly any water flow . Weld a 5/8 plate of aluminum to the timing cover were the water pump sits and no cavitation.
Re: PRW water pump works GREAT!! [Re: MattW] #1060328
08/24/11 09:24 AM
08/24/11 09:24 AM
Nope, I cant get the pictures off my card, Piece of crap anyways. Ill do a little mor reserch today and see if I can find some pictures.
Kasey
Re: PRW water pump works GREAT!! [Re: Moparnut426] #1060329
08/24/11 04:08 PM
08/24/11 04:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Kasey, I'm glad you got your overheating problem fixed. I went through the same thing a few years ago with my 340. I ended up with a Flow Kooler pump, pretty much the same as yours but has a steel impeller with a anti cavitation plate on it. I installed the pump on my 408 and even on the hottest days it seldom goes over 180*, most of the time 170-175*.
Re: PRW water pump works GREAT!! [Re: justinp61] #1060330
08/24/11 04:10 PM
08/24/11 04:10 PM
