Gotta CAM question thats been bugging me... #1059694
08/22/11 11:25 PM
08/22/11 11:25 PM
Oklahoma City OK
Cudajon Offline OP
Cudajon  Offline OP
Oklahoma City OK
In all the cam catalogs they will show a cams operating range like 2500 - 7000 rpm. But those are always for stock or nearly stock displacement engines. So with my 494 what would be a good rule of thumb for adjusting the operating range of the CAM or is there one?
Re: Gotta CAM question thats been bugging me... [Re: Cudajon] #1059695
08/23/11 12:18 AM
08/23/11 12:18 AM
SoCal
Brian Hafliger Offline
SoCal
But from a competent engine builder! There's so many things to take into account when picking a cam, you might as well get your moneys worth.
Brian
Brian Hafliger
Re: Gotta CAM question thats been bugging me... [Re: Cudajon] #1059696
08/23/11 11:42 AM
08/23/11 11:42 AM
Az
Crizila Offline
Crizila  Offline
Az
"GENERAL" rule of thumb: For every 50 cubes more over stock, the power range drops 100-150 rpm - from advertised.
Fastest 300
Re: Gotta CAM question thats been bugging me... [Re: Cudajon] #1059697
08/23/11 12:55 PM
08/23/11 12:55 PM
Big motors like big cams, they really mask the duration and overlap that a smaller motor will see and limit the idle quality and throttle responce. Any grind under 260 at .050 and ground on a 108 or 110 lobe center will work, more lift the better This is a very general statement so keep that in mind, your always better off in dealing with a competent source(cam grinder, engine builder of motors like yours) of informamtion when picking cam grinds :scopeout
Re: Gotta CAM question thats been bugging me... [Re: Cab_Burge] #1059698
08/23/11 01:58 PM
08/23/11 01:58 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Take those operating ranges with a grain of salt.
As an example. A recent 408 was done with a 60403 Lunati, Lunati says the operating range is 1800-6200. The 408 was done at 5300-5400. That cam may have made it to 6200 if it was a 340. How would the same cam run in a 273?
I usually assume the RPM range they state is the middle of the ovarall engine family size range.
With a 494 and a cam that has a catalog 7000 top range, I'd bet it's all done producing incremental HP by 6200 or so.
Talk with an engine builder and see what they say. Most of the time, custom cams can be cut and priced real close to the shelf stuff, if not better.
Re: Gotta CAM question thats been bugging me... [Re: Cudajon] #1059699
08/23/11 02:25 PM
08/23/11 02:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Plus where its installed at will change the rpm
(advancing it will lower the rpm for max power)
Re: Gotta CAM question thats been bugging me... [Re: MR_P_BODY] #1059700
08/23/11 05:18 PM
08/23/11 05:18 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
most important factor in rpm range is cylinder head flow. good flowing heads will require less duration to make the same power and rpms as a bad flowing head and more duration. actuall will make more HP. study things like CSA and choke of the port.
