Rust Holes Repair #1059229
08/22/11 02:00 AM
08/22/11 02:00 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I have some spots on a quarter panel with a few pin holes due to rust. A typical holey section is about 3"x3". See the dark spots in this photo (or here... http://www.creative-machining.com/claylahatte/auto/1971cudaconv_java/#IMG_1634.jpg).
The areas have been blasted both sides and are clean. What would be the best way to repair these kinds of areas?
A simple fix might be to put something on the backside, like fiberglass, and skim the outside with body filler. Or, I could possibly weld these holes, but I would hate to make them bigger by burning metal, not the mention the possibility of distorting the panel shape.
What do you think?
Thanks.
Re: Rust Holes Repair [Re: lahatte] #1059230
08/22/11 08:36 AM
08/22/11 08:36 AM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
HOLY $*** THIS PROVES ANYTHING CAN BE DONE. I'm speechless and your nuts. How many hours do you have in that thing?
Re: Rust Holes Repair [Re: 340swing] #1059231
08/22/11 12:36 PM
08/22/11 12:36 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The problem is getting to the backside. And more importantly, getting all the crud out thst caused it to rust from the inside out. I'd suggest cutting out a square to get to the inside, try to vacuum out all the crap, then patch the hole with good metal.
My quarters had a good 4-5" deep pile of dirt, rust flakes, etc between the outer skin and the inner panel. I couldn't access it till I cut the quarter off.
Plus, the inner panel will be just as soft and rusty and needs fixed too. It's easiest to remove the whole quarter to find all the hidden rust, fix it, and patch the quarter and re-use, or get a new quarter.
**Photobucket sucks**
Re: Rust Holes Repair [Re: lahatte] #1059232
08/22/11 12:49 PM
08/22/11 12:49 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Do it properly; cut out the rusty section and weld in new metal. Looks like you will have too much time and effort into this car to start "half azzing" it now.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Rust Holes Repair [Re: 70Cuda383] #1059233
08/22/11 01:17 PM
08/22/11 01:17 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If you had looked at the pictures you would have seen that there is no back side.
First off - you are crazy - it's a good crazy, but still crazy. I think I would have started with a better car.
My suggestion would be to cut out the section and weld in a patch. It looks like to big an area for welding the holes.
Re: Rust Holes Repair [Re: 70Cuda383] #1059234
08/22/11 03:23 PM
08/22/11 03:23 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
The trunk extentions have been removed, so all the metal is exposed for blasting. There are some other similar spots as well.
I agree about the not half-assing at this point, but a pair of quarters is another $1000+, and these are attached so nicely to the rocker panels. I'm still thinking about replacing them.
Yes, I'm nuts. It's been quite a job, a bit more than I anticipated, with having to replace the firewall, but at least it will almost be a new car. And hey, it ain't nothing but a thing.
Re: Rust Holes Repair [Re: lahatte] #1059235
08/22/11 03:28 PM
08/22/11 03:28 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
By the way, knowing that both sides of the metal are clean, what would be your concerns if using fiberglass, or something similar, as a backing to support a skim of filler on the outside? Do you think the filler might crack or break at the interface, causing the paint to crack? These are small holes, and generally the metal without holes is in decent shape.
Thanks.
Re: Rust Holes Repair [Re: lahatte] #1059236
08/22/11 03:46 PM
08/22/11 03:46 PM
DPelletier Offline
DPelletier  Offline
Thanks.
Yep, I think that at some point the filler will crack and the metal will start rusting again. Clean or not, metal that has pitted is 10x more likely to rust than metal that hasn't been rusted/pitted. Filler isn't meant for this kind of repair and fiberglass is a bandaid. If I ever found fiberglass on the back of a panel, I'd run, not walk away from the car.
Do it once, do it right.
Re: Rust Holes Repair [Re: DPelletier] #1059237
08/22/11 03:50 PM
08/22/11 03:50 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Ok. Sounds reasonable to me. I'll weld the ones I can. Where that doesn't work, patch panels, or just new quarters.
Speaking of Band-aids, the guy I got this car from would "repair" rust by stuffing paper in it and covering with fiber glass, body filler, etc. That's just weird.
Re: Rust Holes Repair [Re: lahatte] #1059238
08/22/11 04:10 PM
08/22/11 04:10 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hmm,well then,as long as the metal is clean,you should not weld it properly,why spend money on bondo?maybe you could use a quality duct tape over the holes,and then paint thick, several layers over the repair. sorry did i say all that ..really if the fit of the quarters are nice and the holes are repairable,just weld them up with patches, remove the bad metal and put new in.or you could get a new lower section.just dont bondo it.
Re: Rust Holes Repair [Re: cuda-sweden] #1059239
08/22/11 04:52 PM
08/22/11 04:52 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
Man! You can fix ANYTHING with Duct Tape.
Re: Rust Holes Repair [Re: lahatte] #1059240
08/22/11 05:36 PM
08/22/11 05:36 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
So what does it take to convert a hardtop to a vert? I have a 71 383 2bbl sitting around doing nothing. Would be cool as a vert!! As for the metal, just cut out the old, weld in new. Pinholes just weld up while using a flat piece of copper as a backer.
Chris from New Jersey
Re: Rust Holes Repair [Re: fig426] #1059241
08/22/11 06:43 PM
08/22/11 06:43 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I've been using brass, but copper would probably be better.
Making a convertible... well, it depends, I suppose, on how much you care to fabricate yourself, as opposed to obtaining from a convertible donor car. Other than the obvious ones, there are several differences, such as trunk hinge supports, windshield frame, reinforced rockers, and reinforced inner structure that holds the top assembly. The top well opening has a gutter/structural system which collects and drains off water. Then there are all the convertible-specific molding and interior pieces.
As far as I know, Ken Hopperdietzel does the best conversions.
Re: Rust Holes Repair [Re: lahatte] #1059242
08/22/11 09:42 PM
08/22/11 09:42 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Thanks Clay,
If you need any convertible conversions pics let me know. I can make over 70% percent of the ebody convertible parts. Check out my website sometime.
Re: Rust Holes Repair [Re: Convertcuda] #1059243
08/22/11 09:48 PM
08/22/11 09:48 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I didn't know you had a website? Address?
Re: Rust Holes Repair [Re: lahatte] #1059244
08/23/11 08:32 AM
08/23/11 08:32 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I HATE doing rear quarters because if the outside is rusted, the inner panel is garbage too. Cutting out both sections, welding in new tin, grinding, doing everthing twice, really bites it. I really, really detest it because there's so many 1/2 day inexpensive alternatives.
But I do it.
Re: Rust Holes Repair [Re: Commando1] #1059245
08/23/11 08:50 AM
08/23/11 08:50 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
But I do it.
I understand your frustration! I've been working on this for about a month now. the other day I was thinking "man, it'll be a shame to cover up all this work so no one will ever see it!
you can see the fresh metal compared to replaced metal because the fresh is still silver, the original turned black from the rust converter.
Re: Rust Holes Repair [Re: 70Cuda383] #1059246
08/23/11 09:12 AM
08/23/11 09:12 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
But I do it.
I had these same feelings, actually I've been working on the rear frame rails, rear frame brace, rocker corners, outer wells,etc, for about a year and a half, and my neighbors stop by and say," wow not much progress", they don't understand all the work that goes on behind the scenes. I guess we can still climb up inside the wells, and look behind the quarters from inside, and appreciate all the work we've done when its all done.Just got past this same repair, good luck.
Re: Rust Holes Repair [Re: cudabitten] #1059247
08/23/11 10:20 AM
08/23/11 10:20 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Gettin back to the original post, I agree, 1/4's are expensive, if you can save what have, its worth it. I also agree filler probably is not the fix for pin holes in that area, but Mig'in pin holes shut, is the most difficult things for me anyway. copper back or not, plus your welding out of position. I've seen on another site where they repaired an area like that by cleaning the metal, then treating with something like picklex,(rust converter/treatment), then used aluminum tape as a backer, and filled the front with a polyester, waterproof filler. There may have been other steps involved. The site is called autoybodystore.com. there are alternatives,you can also coat the back with a rust encapsulator. Guys on that site have had repairs last for over ten years like that.
Re: Rust Holes Repair [Re: cudabitten] #1059248
08/23/11 11:40 AM
08/23/11 11:40 AM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
That reminds me, there's that body panel glue that the shops use now. I understand it holds like mad. With that I should be able to cut some patch metal and just glue it to the backside of the rust holes areas. That might just be the ticket. I had thought about doing that originally, but it slipped my mind.
Thoughts on that approach?
