Can You Still Buy Galvanized Spangle Finish Metal ?? #1058837
08/21/11 07:20 PM
08/21/11 07:20 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I am looking to see if there is any where you can still buy a sheet (approx 60"x12") of flat galvanized metal that has the "spangle" finish.You know like on the old metal pails and numberous auto parts.I thought I read one time that this process is no longer done in the states because of EPA but is still available in Canada.Can any one give me some leads or maybe someone can sell me some.I am looking at trying to make a part that originally had this finish.Thanks !!
Re: Can You Still Buy Galvanized Spangle Finish Metal ?? [Re: 44D6PAKCUDA] #1058838
08/21/11 08:01 PM
08/21/11 08:01 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
There's two type of galvanizing done, hot dip and electro-galvanize. Either method will produce the spangle finish which is more dependent upon the chemistry of the steel than the process. Here's a little light reading on the subject.
Small orders are sometimes difficult. Have you checked your local steel warehouses? Around here we have two that cater to the public, Norton metals and Metals Supermarket.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Can You Still Buy Galvanized Spangle Finish Metal ?? [Re: 3hundred] #1058839
08/21/11 09:24 PM
08/21/11 09:24 PM
Thanks for the info and link.The type of finish I am looking for is the more defined "flake" pattern as I think the dip galvanizing process comes out thicker and not as smooth.Do your local sources offer this finish in sheet form do you know? Thanks !!
Re: Can You Still Buy Galvanized Spangle Finish Metal ?? [Re: 44D6PAKCUDA] #1058840
08/22/11 11:48 AM
08/22/11 11:48 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
We do very little with sheet metal and even less with galv. sheet metal. In addition to local steel warehouses you could also try steel service centers.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Can You Still Buy Galvanized Spangle Finish Metal ?? [Re: 44D6PAKCUDA] #1058841
08/22/11 12:39 PM
08/22/11 12:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I won't get into the chemistry of the issue, but the short answer is that the previous poster is correct; you can get spangle either way. I buy about 10,000 sheets of galvanized metal a year and some has spangle (in varying sizes) and some does not. Even the largest spangle we get now isn't quite as big as the stuff from 30-40 years ago but it still has noticeable spangle and would likely suit your purposes fine.
You won't be able to order what you want; go to a large sheet metal shop and ask to see the metal and pick something you like.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
