Re: !!!Broke my auto trans tail shaft!!!! what cause it
[Re: mopar65]
#1058740
08/21/11 06:38 PM
08/21/11 06:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think when you took out the rear it cracked the tail, since you said the drive shaft is fine and you dont have any vibrations.... I'm thinking you never looked to see if it was cracked.... then add a few more launches and.... you know
[Re: mopar65]
#1058744
08/21/11 07:14 PM
08/21/11 07:14 PM
MR_P_BODY
thanks for the info guys. I am pretty sure i checked everything over.but maybe i missed the tail shaft. so do you guys think i could just install a new tail shaft and be ok? the car did drive on the trailer under its own power and i was running around 125-126 mph in the 1/4 last nite? thanks bobby
ALL cars flex its just a mater of how much... I think the car flex took it out.... even with the rubber mount... and being NEW its stiffer than a old one..... JMO
[Re: mopar65]
#1058746
08/21/11 07:17 PM
08/21/11 07:17 PM
Posts: 635 mississippi
bentwheel43
mississippi
Hi man,I broke 3 just like that,turn out my driveshaft was 1" to long.~~~ bentwheel43
Section 8 Racing We are nuts about racing.
[Re: bentwheel43]
#1058747
08/21/11 09:08 PM
08/21/11 09:08 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
When my diff broke it did cause the tail shaft to break in about the same place. It was on the launch off a T brake so it was instant and a little more violent then yours was.
I would suspect that yours was cracked when your diff broke then just took a little longer for it to come apart.
FWIW, my output shaft was OK and just needed a new tail shaft housing but definitely get your checked.
[Re: DaveRS23]
#1058749
08/21/11 10:29 PM
08/21/11 10:29 PM
MR_P_BODY
They all break in the same place... through the speedo hole... its just the weak point of the tail shaft... its a matter of what causes it... I have a buddy that has a quick car that went through 3 tail shafts in 4 weekends... his was a bit different but he has a front plate, mid plate and he was running a solid trans mount... I told him the first time to get rid of the solid trans mount... he didnt... then after the third he finally did... since then its been fine.... you cant tell how much flex a car will have
[Re: mopar65]
#1058750
08/21/11 10:32 PM
08/21/11 10:32 PM
Posts: 2,177 ill
dennismopar73
ill
sometimes it hard to say what broke yours? i know of allot of them that racers i personaly know , and race with have broken so many and with diffrent trans in same day that now they carry couple as spares, now for me , i have never broke a 1 not a single one ,, one can blame a previous breakage, etc, i have even heard that tires being out of balance will do it to? ring pinion gears , lose pinion nut,, so i wouldnt say could be all the above, i waiting for someone to mount a camera on that area, and look n see what type of flex is going on in that area during launch and de-accelleration, and what type of forward/rearward movement get involved as well, during a run? just a thought
[Re: mopar65]
#1058754
08/21/11 11:23 PM
08/21/11 11:23 PM
MR_P_BODY
thanks for the replys guys.I am still runing the 8-3/4 in my dart. dont have the money for the dana yet.I am running the 318 to big block coversion motor mounts and the stock tansmission mount.I will have to check to make sure. but i think i have over a inch of the yolk sticking out of the tail shaft.how much are you soposed to have? i know stuff breaks but this is a frist for me.yes i would like to find one out of a van or a truck. i have heard they are stronger.I have another tail shaft i am going to put on it.for no so at least i can move it off the shop floor if i need to and have to wash all the trans fluid off the bottom of the car.i might just find another trans to build up and use this one for spare parts. or if you guys think i will be ok to just put a new tail shaft on this one and try it again?thanks Mopar65
Should only have 3/4" on the drive shaft length... so bottoming out sure wasnt the problem
[Re: MR_P_BODY]
#1058755
08/21/11 11:51 PM
08/21/11 11:51 PM
WILD BILL
BROOK PARK, OH
When mine broke I went through the trans to check everything and it was all good so I put a new tail housing on and let er rip.
