How to fix leaky differential? *DELETED* #1058686
08/21/11 03:12 PM
08/21/11 03:12 PM
illinois
bigblk66_coronet Offline OP
illinois
Post deleted by bigblk66_coronet
Re: How to fix leaky differential? [Re: bigblk66_coronet] #1058687
08/21/11 03:16 PM
08/21/11 03:16 PM
MI
68shifter Offline
68shifter  Offline
MI
Ford and Chevy have a grey silicone that works great. OE's use it everywhere on newer engines with no gaskets-Duramax top ends are practically held together by it.
Try that. Otherwise make sure housing flange true, good holes etc....
Good luck.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: How to fix leaky differential? [Re: bigblk66_coronet] #1058688
08/21/11 04:27 PM
08/21/11 04:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont use a gasket on my 8 3/4... I run a bead of
Mopar black silicone and put the 3rd in place but only
make the bead flat(about .020 or so) from it being
tight then let it set up over night then tighten it
up the next day... I also go around each stud with
the silicone
