#1058655 - 08/21/11 12:37 PM ECU gone bad. What do you guys use?
MoparDonny Offline
Loc: Port Alberni, British Columbia
I know it's been talked about as many times as pinion angle, but..............
My Dad runs the FBO stuff and it works great but I'm still using Mopar stuff, currently Chrome box and Chrome coil. I am going to replace the coil and the Chrome ECU because i had to borrow them from my dads spare parts box at the races last week. My car would hit 6200 and that was it, felt like a rev limiter. I've heard guys having good luck with NAPA stuff but thought I'd ask before buying.
Thanks.
Don.
'71 451 Challenger 3.91's and 3" X with Spintechs BEST TIMES : 7.349 @ 96.14 ,1.609 60 ft at an airport. 11.71 @ 115.62 1.64 60 ft also at an airport. '04 Ram 1500 HEMI '04 SX 2.0
#1058656 - 08/21/11 12:38 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
CrAzYMoPaRGuY Offline
Loc: Canada
I think I'm going to try the new FBO stuff on my Charger...
CrAzYMoPaRGuY
#1058657 - 08/21/11 12:40 PM Re: ECU gone bad. What do you guys use? [Re: CrAzYMoPaRGuY]
MoparDonny Offline
Is the FBO stuff recommended for daily driver use though? I don't make long trips but I drive it a fair bit.
#1058658 - 08/21/11 12:44 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
Loc: Canada
I have the original FBO setup on my Jensen- the A688. I daily drive my Jensen and go out for hours at a time, runs like a clock. It's been running well over a year.
The new setup is supposed to be more powerful, but I haven't tried it yet.... others will have to chime in.
CrAzYMoPaRGuY
#1058659 - 08/21/11 02:11 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
MR_P_BODY Offline
Loc: Romeo MI
How long have you had that chrome box on it... things
do wear out... my fist ignition was the gold box but
thats not for the street
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#1058660 - 08/21/11 04:02 PM Re: ECU gone bad. What do you guys use? [Re: MR_P_BODY]
MoparDonny Offline
I'm gonna guess 4 or 5 years max. This might be 5th summer with it. I only put 500 miles a year on the car at most. I had heard someone say before that the boxes NAPA carries seem like good quality
#1058661 - 08/21/11 04:24 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
MR_P_BODY Offline
Loc: Romeo MI
To me... if its a street car I want something I can
get anywhere to get me home... a race car I use MSD
because most guys use it and I MIGHT be able to
get a part at the track if I have a problem.... I
always look for easy access to stuff like that...
I dont know if NAPA is better or not
CAR IS FOR SALE
#1058662 - 08/21/11 05:50 PM Re: ECU gone bad. What do you guys use? [Re: MR_P_BODY]
J_BODY Offline
Loc: aZLiViN
Back in my street days I ran a chrome box that started giving me fits, especially when hot. I lengthened the wiring and moved it up to the front of the radiator support. Worked like a champ until I finally went complete MSD as the car had become full time race.
#1058663 - 08/22/11 02:44 PM Re: ECU gone bad. What do you guys use? [Re: J_BODY]
Paul_Fancsali Offline
Factory 4 prong control box or convert to pertronix. I for one only use the Mopar elec for backup ignition All is there except dist which I carry in a tool box
#1058664 - 08/22/11 07:26 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
Sinitro Offline
Loc: So Cal
Before chucking the chrome box..
Be sure to check your ground connections for the box closely, these need to be tite & kleen..
Just my $0.02...
#1058665 - 08/22/11 08:41 PM Re: ECU gone bad. What do you guys use? [Re: Sinitro]
Hot 340 Offline
Loc: Pa
Just my $0.02...
Some real good advice here ^.. I had a chrome one do that and wasnt grounded well.. also burnt a couple of chrome boxes up using an accell super coil. You might want to consider a stock oe black box, mine never misses a beat, but I dont go past 6700.
#1058666 - 08/22/11 09:06 PM Re: ECU gone bad. What do you guys use? [Re: Hot 340]
toddd Offline
Loc: British Columbia
Don, I'll double check but I've got a FBO ecu i haven't used...still in the box.
it's your if you want it.
#1058667 - 08/23/11 08:52 PM Re: ECU gone bad. What do you guys use? [Re: toddd]
MoparDonny Offline
Todd, you going to McNeill on Friday?? I'll be there late but I'm going right after work. Probably get there around 10PM
Don.
#1058668 - 08/23/11 08:56 PM Re: ECU gone bad. What do you guys use? [Re: Hot 340]
MoparDonny Offline
I never need more than 6500 at absolute most anyway, but it's embarrassing when it pops like a chevy.
#1058669 - 08/23/11 08:59 PM Re: ECU gone bad. What do you guys use? [Re: MoparDonny]
toddd Offline
I'm going to...just waiting for a F****'n t/o bearing, so i can put the car together again....6 times this year so far.
I'll bring it.
25,485 Registered Members
192,955 Topics
wing car avon bottle $6.99
by EV2Bird
Yesterday at 11:28 PM
72-74 factory Rear sway bar
by Fasbird
Yesterday at 11:06 PM
1969 Plymouth Valiant 2DR
by FM3_1970
Yesterday at 10:52 PM
Scored a Demon yesterday...
by 68SportFury
Yesterday at 10:38 PM
