Moving in leaf springs on an Abody Questions????? #1058636
08/21/11 02:30 PM
08/21/11 02:30 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I will be eventually going to Ladder bar setup before the ice drags start but I don't have the extra 2K to stick into it right now. But in 3 weeks we are going to the drag strip and I would like to at least move the leaf springs in and narrow the rear a bit so the tires fit under the car. Maybe even drop the rear down if possible. I would like to fab as much as possible. I have Cass's axles so I can cut them down 2.5" a piece before the splines will bottom out on the spool.
My questions are;
I'd like to reuse as much of the stock suspension parts as possible since I will be only using this for a short time and don't want to waste too much money. So what will I absolutely have to buy??? Off set shackles?
I have SS springs now 002 003, is there any way to drop the rear with these? I do have the old sagged stock springs.
I also need measurements/steel thickness on the box that gets welded to the frame rails that the leaf attaches to.
If I'm missing anything please feel free to chime in. Like I said this is just a temporary deal so I don't want to buy much, since I can fabricate pretty much everything myself.
Thanks guys
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058637
08/21/11 04:37 PM
08/21/11 04:37 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My questions are;
Thanks guys
I have an old direct connection leaf spring relocation kit and you would be suprised at the quality. The box is 1/8 steel and if you want I can go outside to get the measurements. The offset shacles where heavy duty but you don't need them just drill the frame and slide the proper size tube and bolt a regular shackle.
This way I believe you would lower the height along with drilling multible holes on the front hanger to lower it some more. Matt
Re: Moving in leaf springs on an Abody Questions????? [Re: MattW] #1058638
08/21/11 06:08 PM
08/21/11 06:08 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have been forced to make these kits on more than one occasssion. The customer was a tight wad and would not buy the kit. After charging what I needed to in labor they could have bought two kits.
Why do you want to cut the axles down? You can buy wheels to accomodate your rear width.
A ladder bar setup should not be that expensive. If you do the relocation all you have to do is weld a ladder bar crossmember to the spring relocation boxes. Are you looking at going coilovers too?
Leon
Re: Moving in leaf springs on an Abody Questions????? [Re: Leon441] #1058639
08/21/11 06:41 PM
08/21/11 06:41 PM
Menomonee Falls
Menomonee Falls
Yes I was going to do the Alston Chassisworks ladder with double adjustable coilovers. With the wheels I want it will be around 2k.
Wheels are expensive, I can narrow the rear, cut the axles down and have no money invested just my time.
I can't see how making two small boxes out of 1/8" steel can cost $400 Please help me understand where the time comes in. I understand cleaning the frame rails and prepping everything for welding. I must be missing something here.
SDG Motorsports
Re: Moving in leaf springs on an Abody Questions????? [Re: MattW] #1058640
08/21/11 06:45 PM
08/21/11 06:45 PM
Menomonee Falls
Menomonee Falls
If it's not too much to ask, I'd like the measurements if you could
Also does anyone have pics of ones they have done? Just so I can get an idea of what all needs to be done.
What is the reasoning for the offset hangers?
SDG Motorsports
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058641
08/21/11 06:59 PM
08/21/11 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I think your wasting your time moving the springs
in for a few months and then changing over to a ladder
bar... run what you have now for the summer and
put the ladder bar in... if you want to go cheap
buy the front cross bar... make your own ladder bars
and put sliders on it(I think the sliders is the wrong
way to go)................ JMO
Re: Moving in leaf springs on an Abody Questions????? [Re: MR_P_BODY] #1058642
08/21/11 07:27 PM
08/21/11 07:27 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I made my own boxes from 3/16" because the ones you buy are a little flimsy and the inside diameter is too big, i also put extra holes in.
As said before weld tubes through the chassis rails and fit the rear hangers, i also beefed the rails up on both sides of the tube.
Mr P
I think he only races in the winter.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Moving in leaf springs on an Abody Questions????? [Re: deaks] #1058643
08/21/11 07:35 PM
08/21/11 07:35 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I drilled out the spot welds and moved the stock frame rails on mine. Then added a 4" section to the stco wheel tubs. Wasn't real time consuming. I have 12 x 29.5 GY's under it now. It's a 69 Dart. Jim
Re: Moving in leaf springs on an Abody Questions????? [Re: rt66jim] #1058644
08/21/11 08:19 PM
08/21/11 08:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
When you are ready to do it, pull your leaf springs and measure the width of the bush. Most kits you buy, the box for the front spring eye is too wide. You will need a tube to put through the rails for the rear shackle, or you can run an Afco slider in the rear. Personally, I would just leave it and wait until you have the $$$ for the Ladder bars. Personally I think it is going to look like crap underneath the car if you had the rails cut out and empty spring mounts along with the Ladder bar cross member. Unless of course you mount the spring mounts on the inside of the rails and remove them when the ladder bars are installed. You've obviously got alot of time up your sleeve
Alan Jones
Re: Moving in leaf springs on an Abody Questions????? [Re: deaks] #1058645
08/21/11 08:30 PM
08/21/11 08:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mr P
Mick
From what I'm getting he has something coming up on
a NORMAL track but yes I know he ice races... What
I get he is gonna to this twice... move the springs
then go ladder bar
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058646
08/21/11 08:32 PM
08/21/11 08:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
These were sent to me by another member here.
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058647
08/21/11 08:32 PM
08/21/11 08:32 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Go to this web page www.scottysplace.net
Re: Moving in leaf springs on an Abody Questions????? [Re: justinp61] #1058648
08/21/11 08:32 PM
08/21/11 08:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Another.
Re: Moving in leaf springs on an Abody Questions????? [Re: justinp61] #1058649
08/21/11 08:54 PM
08/21/11 08:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I did the spring relocation then went to ladder bar,save your time and money ,do the ladder bar setup with coil over shocks. Even with cheap shocks you'll be better off than trying to get those heavy leaf springs to work the way the ladder bars will. PM me and I'll tell you a easy way to do it.
Re: Moving in leaf springs on an Abody Questions????? [Re: rowin4] #1058650
08/21/11 09:47 PM
08/21/11 09:47 PM
Menomonee Falls
Menomonee Falls
Yes, I will be taking the duster down the 1/8 mile asphalt strip at WIR.
Half the reason I want to do something with the rear end is because the current housing is twisted
I am going to use a 67 truck housing for now, narrow it and backbrace it. I am working on a triangulated and back braced 8 3/4 for the ladder setup. I have it all drawn up in solidworks already just need to put it to the jig
Steve, sent you a PM
SDG Motorsports
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058651
08/21/11 09:54 PM
08/21/11 09:54 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Why not just buy the kit??? Maybe you don't realize the kit is only just over 100 bucks and its easy to install.
Re: Moving in leaf springs on an Abody Questions????? [Re: viperblue72] #1058652
08/22/11 05:39 AM
08/22/11 05:39 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My mistake.
Mick
best 60ft 1.36
Re: Moving in leaf springs on an Abody Questions????? [Re: DemonDust] #1058653
08/22/11 08:57 AM
08/22/11 08:57 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Just my opinion wouldn't be better to sell your 8 3/4 and build a dana
Re: Moving in leaf springs on an Abody Questions????? [Re: MattW] #1058654
08/22/11 10:35 AM
08/22/11 10:35 AM
Menomonee Falls
Menomonee Falls
I change gears to much. I don't want to lose ease of changing them in 45 mins lol.
And I'm partial to 8 3/4. I don't think I could ever go dana.
SDG Motorsports
