Cant get small block head bolts locally? Really? #1058617
08/21/11 01:59 PM
08/21/11 01:59 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Just got off the phone with all the "normal" local parts stores trying to find head bolts for my LA 360. Not a single store has them, can order them, or even lists them. You've got to be kidding!
I bet if I had a hunk-o-crap recycled pop can Honda civic I could get some dang head bolts.
Parts stores suck. Looks like I wont be getting this engine together today.
Laine.
NRCA Member
Re: Cant get small block head bolts locally? Really? [Re: Lmopar69] #1058618
08/21/11 02:01 PM
08/21/11 02:01 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Hmmm... just remembered, if Im correct, 273, 318 and 360 head bolts are all the same part. I wonder if they list them for a 318.... time to check.
ANSWER: Of course they dont. Tried every parts store thats open today, nothin, nothing at all. I find this to be very odd.
Laine.
NRCA Member
Re: Cant get small block head bolts locally? Really? [Re: Lmopar69] #1058619
08/21/11 02:26 PM
08/21/11 02:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
ahhh, Mopar. that's why we're a special breed! you should see what it's like in big block world
Re: Cant get small block head bolts locally? Really? [Re: mikemee1331] #1058620
08/21/11 02:35 PM
08/21/11 02:35 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
It just drives me nuts. I should use ARP bolts anyway like I did on the mains and rods, but dang, you should be able to get stinkin head bolts for some of the most common dodge engines on the road.
Guess I'll call Summit and get them in the mail. Doubtful that the local Dodge dealership has them either. I asked them for head gaskets, took 5 days to get them, but, I ordered them anyway.
Laine.
NRCA Member
Re: Cant get small block head bolts locally? Really? [Re: Lmopar69] #1058621
08/21/11 03:22 PM
08/21/11 03:22 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Mopar SB head bolts are NOT torque to yield bolts i.e. they dont need to replaced. That's why you cant find them.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Cant get small block head bolts locally? Really? [Re: HemiRick] #1058622
08/21/11 04:36 PM
08/21/11 04:36 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Well, I guess that sheds a bit of light on it. But, would you build a new engine and not replace the head bolts?
Laine.
NRCA Member
Re: Cant get small block head bolts locally? Really? [Re: Lmopar69] #1058623
08/21/11 06:57 PM
08/21/11 06:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Laine.
That depends on if I know the history of the engine,however I do prefer studs on the mains and heads.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
