SB? Improving oil drain back
#1058581
08/21/11 01:18 PM
08/21/11 01:18 PM
Triple Threat
Renton Washington
My current 340 with Edelbrock heads holds a ton of oil up top, its a guarantee that anytime I pull a valve cover oil gets on the headers. Is there any way I can help this or is it just the nature of the beast with these heads?
Any tips or tricks?
Re: SB? Improving oil drain back
[Re: Brian Hafliger]
#1058583
08/21/11 02:12 PM
08/21/11 02:12 PM
Triple Threat
Renton Washington
1.6 Cranes, This question is for an engine i'm building currently, so everything is apart.
[Re: sshemi]
#1058585
08/21/11 03:18 PM
08/21/11 03:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
#6 external drainback lines to the pan.
You can restrict oil to the rockers. I probably would not do this with Cranes as there are no bearings.
Leon
[Re: Leon441]
#1058586
08/21/11 03:54 PM
08/21/11 03:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leon
This is what I would think also... just like doing a set of B-1 heads.... they hold a ton of oil
