Launch issues....
#1058563
08/21/11 01:13 PM
08/21/11 01:13 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Well...the Arrow has developed an issue where every once in awhile it will hike up one of the front tires during the launch. This will usually cause me to be way late or red. Last night this happened in the fourth round...my previous lights were .019,.001,.004 then in the third round the left tire went up and I was .064 I assume it's planting the right longer causing the late leave.
I have played with shock settings and tire pressure since it seemed at 6.5 lbs the car was wadding the tire up....I'm at 7.75 now. I also took one click out of the left shock and for the TT and first 3 rounds all seemed well. The shocks and springs are probably as old as half the members here so one or both could be the issue.
Any ideas?...I leave off the wood at 5600 so the car hits like a son of a itch. I don't have a two step and would rather not make that change since it seemed fine last year.
Maybe a heim sticking?.....HELP...this is killing me.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Launch issues....
[Re: Eric]
#1058565
08/21/11 01:25 PM
08/21/11 01:25 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Strut front or shock front car?
RIP Monte Smith
[Re: CompWedgeEngines]
#1058566
08/21/11 01:41 PM
08/21/11 01:41 PM
Eric
Pittsburgh PA
Shock front...4 link.... I wonder if one of my limiters (cables ) is broken. It doesn't happen all the time though
[Re: Eric]
#1058568
08/21/11 01:50 PM
08/21/11 01:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Time to look it over very closely... look for cracked welds, bent shocks(or oil on the shocks)... look at both ends of the car, check your heims and give the car a clean and lube job
[Re: Eric]
#1058569
08/21/11 08:37 PM
08/21/11 08:37 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Dave...stuff wears out? ....do you realize who you are talking to
Dave was having a senior moment when he typed that ---- But he is THE GUY I turn to for any help on my car
Russ
[Re: max_maniac]
#1058570
08/21/11 08:55 PM
08/21/11 08:55 PM
Posts: 2,289 NE Ohio
DoubleD
NE Ohio
Russ
Senior moment? maybe a Junior moment after all your older than dirt! By the way your new Race Car is done - when can I pick up the Challenger? I found the suit also.
Eric I forgot you still have your first communion money - no wonder Bob George whips on you - just open the wallet and let them dollar bills breath!
