steering column problem #1057968
08/20/11 03:15 PM
08/20/11 03:15 PM
kentucky
jstewart Offline OP
jstewart  Offline OP
kentucky
im sorry if i posted this in the wrong area but ive just changed the steeering box on my 73 barracuda and when i drove it, it had just as much play in it as it did before, how do i make sure the splines on the shaft lined up correctly?
Re: steering column problem [Re: jstewart] #1057969
08/21/11 11:27 PM
08/21/11 11:27 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
There's a master spline on the box that gets clocked at the 12 o:clock position...Steering wheel/shaft goes on accordingly...Anyhow...If you've still got slop with a new box two things come to mind... Either there's worn steering/suspension components or the steering coupler needs rebuilt...
