Re: Eddy single 4 intake for 5.7 ??
[Re: patrick]
#1057924
08/23/11 10:49 AM
08/23/11 10:49 AM
Posts: 2,826 NY usa
540challenger
NY usa
Still costs way more than a carb set up would, even the eddy with two carbs
I think I am gonna look into the mod-man intake, I am concerned with low speed fuel distribution but it looks to be the cheapest way
even taking into account the $800 spark computer for the distributorless ignition?
With EFI he is also going to need to upgrade the fuel system electric pump filter and etc.... that will add up fast too.
[Re: 540challenger]
#1057925
08/23/11 12:31 PM
08/23/11 12:31 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
Summit has an MSD ignition controller for $475 and right now you can get a $40 rebate on that. For EFI you would have a hard time running the factory controller, it needs to comunicate with the instrument cluster and other crap, FAST makes a controller that is like $3000 XV control is about the same but comes with a complete kit. Either way I don't see it costing less than double the carb route. I can't beleive what I said about the intakes, when Indy has the cheapest of something it must be a cold day in Hades (mopar land)
[Re: STEFF]
#1057926
08/23/11 04:38 PM
08/23/11 04:38 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Instead of complaining, there's market opportunity, make the investment and develop, manufacture & sell an affordable intake.
And for Joe Average, after you get all the engineering and manufacturing design all laid out, the cost vs projected sales volume adds up to...
$800. To break even.
Or you get it made in china, sell it for $500, and get complaints about chinese origin, or poor quality, probably both.
Never thought I'd say it, but when contemplating a new Hemi, I actually think 'just get a 360 Magnum'.
If I was serious about a carb'd 5.7, I'd start looking for V8 engines with the same port pattern (like we saw above), and see if there is one that could maybe fit with some simpler adapter plates. Unfortunately, those intakes won't really be cheap either, but if a simple set of CNC spacerplates does the trick, you'd be a hero.
How close is the 4.6/5.4 for port spacing???
[Re: patrick]
#1057927
08/23/11 05:06 PM
08/23/11 05:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
And that the EFI will make more power over a carb
[Re: Fury Fan]
#1057929
08/23/11 05:24 PM
08/23/11 05:24 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
NO!!! Every 'should I go EFI' thread clearly states somewhere that carbs make more hp.
Both properly tuned carb or efi are equa. EFI has the advantage of easier start and less ring wash.
