Page 2 of 3 1 2 3
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057904
08/20/11 09:52 PM
08/20/11 09:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The sales volume thing is BS because eddy does make the dual quad one with a more complicated casting and less people are gonna use it than they would a single 4. I am not oposed to paying more than a chevy guy for similar parts but this is out in left field even for mopar. Heck even the mopar single 4 not drag-pak intake is $1000 that is FOUR times the price of the chevy one not just double even
Well I guess you can get out your tig welder and make one
Re: Eddy single 4 intake for 5.7 ?? [Re: MattW] #1057905
08/20/11 10:31 PM
08/20/11 10:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Instead of complaining, there's market opportunity, make the investment and develop, manufacture & sell an affordable intake.
my attempt
LOL If the runners line up use a block of wood. Plus you get the thermo break.LOL
I will be flowing the Apache heads in the near future same flow bench as before. Matt
close
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057906
08/21/11 02:48 AM
08/21/11 02:48 AM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So aparently Indy makes one that is the cheapest, they call it a "Mod-Man" and it comes with removable tops to put whatever carb I want on it, any one ever use one of those? How do they do with fuel distribution at lower engine speeds on a stockish 5.7 engine?
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057907
08/21/11 09:21 AM
08/21/11 09:21 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i have a PM sent to TR Waters asking if he has already has a design to adapt an early hemi intake to the GEN 3 engines. i believe he does and if so you can run this intake
Re: Eddy single 4 intake for 5.7 ?? [Re: sixpackgut] #1057908
08/21/11 10:31 AM
08/21/11 10:31 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
my attempt
OK I'm confused, what intake is that for? P7?
Re: Eddy single 4 intake for 5.7 ?? [Re: MattW] #1057909
08/21/11 10:43 AM
08/21/11 10:43 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Not to get into a "who copied whom" debate, these are the intakes my buddy had cast about 5 years ago. He is now making them with a carb top plate. And he was also the first with the tall cast valve covers.
The 2x4 piece is just something I had laying around, so I threw it on that intake.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057910
08/21/11 10:50 AM
08/21/11 10:50 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057911
08/21/11 11:06 AM
08/21/11 11:06 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
The P7 intake is quite narrow, and would require a very thick adapter to make it work. Arrington used one on their first carb build. A SP2P intake is wider , but still not as wide as the 1st gen hemi.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057912
08/21/11 01:16 PM
08/21/11 01:16 PM
Kalispell Mt.
Kalispell Mt.
SO that is interesting I guess it brings up the question how much is that dual plane intake? Who makes it? and how much are the red spacer thingies?
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057913
08/21/11 01:55 PM
08/21/11 01:55 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
The dual plane that Ray posted is from Hot Heads. It lists for $315.00. The problem is, there is no way to make spacers which would incorporate both the gen3 and gen1 bolt patterns. This is why I did mine like I did. One common bolt pattern. Unless you have your own milling machine and tig set-up, you will end up with the $600 or so that the XV intake would cost you.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057914
08/21/11 02:12 PM
08/21/11 02:12 PM
MN
hemidup Offline
hemidup  Offline
MN
Tom, I'm not a big fan of the XV for a N/A motor unless its built for RPM. Dyno'd a 5.7 truck intake, 6.1 SRT8 intake and the XV one day. The truck intake and 6.1 were pretty much neck n neck. The XV was such a pooch that the dyno operator asked me go into the room to check and make sure the throttle blade was opened up all the way.
Jerry Williams.
Re: Eddy single 4 intake for 5.7 ?? [Re: hemidup] #1057915
08/21/11 02:48 PM
08/21/11 02:48 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Jerry,
Just an observation, but seems the gen3 hemi likes those long intake runners. I'll stick to my old stuff.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057916
08/21/11 02:56 PM
08/21/11 02:56 PM
MN
hemidup Offline
hemidup  Offline
MN
Jerry,
Tom, Love your old stuff too. I never did do a back to back dyno with your Gen 3 Hemi intake spacers. All I know is that your custom 1/2" spacer increased the runner length by a 1/2". A 1/2" is the difference between OOOOH and AHAAA. lol
Jerry Williams.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057917
08/21/11 03:00 PM
08/21/11 03:00 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Are those parts avaliable and for sale?
I really like the front cover with the dist.
Re: Eddy single 4 intake for 5.7 ?? [Re: TrWaters] #1057918
08/21/11 04:12 PM
08/21/11 04:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Jerry,
Easiest way to explain it is to flow an exhaust port with a generic header on it even with cold air the temp rise in the header a the first bend is remarkable. That why Dyno headers usually product more.
Truck intake and 6.1 are great for EFI but would run poor if the mixture had to go throught it. That is why the jiggle juice doesn't work so well with those intakes.
IMO a composite intake like the dragpack intake with different heights would work well.
the more i research this the more I am leaning to EFI.
U can pick an 09 to present composite intake from dodge for 214.00.
Matt
Re: Eddy single 4 intake for 5.7 ?? [Re: sshemi] #1057919
08/21/11 04:43 PM
08/21/11 04:43 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
It was all just a personal experiment. Way too costly to produce.....or reproduce....just to say you have a distributor. Cheaper to buy an intake and carb, add the MSD ignition box and go.
I am not sure what my buddy is using for electronics in this car. It is a 671 BDS with EFI.
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057920
08/22/11 09:41 AM
08/22/11 09:41 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
step up to the 1990's and run efi with the stock intake
2017 Grand Cherokee Overland
Re: Eddy single 4 intake for 5.7 ?? [Re: patrick] #1057921
08/22/11 11:01 AM
08/22/11 11:01 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
that would require a wardrode change and i cant afford that!
Re: Eddy single 4 intake for 5.7 ?? [Re: sixpackgut] #1057922
08/22/11 07:54 PM
08/22/11 07:54 PM
Kalispell Mt.
Kalispell Mt.
Still costs way more than a carb set up would, even the eddy with two carbs
I think I am gonna look into the mod-man intake, I am concerned with low speed fuel distribution but it looks to be the cheapest way
Re: Eddy single 4 intake for 5.7 ?? [Re: HotRodDave] #1057923
08/23/11 09:50 AM
08/23/11 09:50 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
even taking into account the $800 spark computer for the distributorless ignition?
Page 2 of 3 1 2 3
