Cheetah neutral start switch install #1057842
08/20/11 11:11 AM
08/20/11 11:11 AM
ont,canada
mopartuner Offline OP
ont,canada
I am trying to install this in my car and am unsure how it goes.Do you only need a wire run to the starter solinoid(ground) from the center lug of the switch on the trans?
410 pump gas solis flat tappet cam 10.95 so far
Re: Cheetah neutral start switch install [Re: mopartuner] #1057843
08/20/11 11:58 AM
08/20/11 11:58 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
The wire from the shifter should go the starter relay/solenoid...
Re: Cheetah neutral start switch install [Re: Jeepmon] #1057844
08/20/11 12:06 PM
08/20/11 12:06 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Re: Cheetah neutral start switch install [Re: Jeepmon] #1057845
08/30/11 01:54 PM
08/30/11 01:54 PM
ont,canada
ont,canada
I got it fixed,thanks
