rear wing struts #1057722
08/19/11 10:32 PM
08/19/11 10:32 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
where would one buy just the adjustable struts to suit the flat wing that extends off the trunk lid? i can manufacture my own wing so i don't need the kit, just the strut. thanx
Re: rear wing struts [Re: rebel] #1057723
08/19/11 11:24 PM
08/19/11 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made mine.... some alum rod, drill and tap the ends
and use heim joints
Re: rear wing struts [Re: MR_P_BODY] #1057724
08/19/11 11:26 PM
08/19/11 11:26 PM
Out West
408strokerdart Offline
Out West
and use heim joints
with Raff. or you can get just the install kit from Ed Quay if you want the tube type moly struts.
Re: rear wing struts [Re: rebel] #1057725
08/20/11 09:50 AM
08/20/11 09:50 AM
Get-X Offline
Get-X  Offline
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: rear wing struts [Re: 408strokerdart] #1057726
08/21/11 03:28 AM
08/21/11 03:28 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
these look trick. has anybody used these with good results?
