Page 3 of 30 1 2 3 4 5 29 30
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055501
09/08/11 12:18 AM
09/08/11 12:18 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
When I sanded the fenders on my Cuda I hit the black V21 paint but there was not red underneath...just grey primer. After talking with Rodger Gibson he confirmed that the black was shot and then the red was shot over it. ...just a thought
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: UCUDANT] #1055502
09/08/11 10:57 PM
09/08/11 10:57 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Delays, delays....I didn't get done what I wanted to today but made use of the time that I had. I noticed that the lower pinch weld area was painted black on both sides. I'm guessing this was done at the same time as when they blacked out inner fender area that can be seen behind the wheel opening in the fender.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055503
09/08/11 11:02 PM
09/08/11 11:02 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres a pic showing a few details. The area under the gas tank was definately black, runs and drips are evident in areas. You can also see the sideways "A" on the rear end.
Were the rear shocks staggered on 340 cars? In this pic you can see the shock extender on the top mount of the passenger side?? Is this stock?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055504
09/09/11 12:01 AM
09/09/11 12:01 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Ohh yeah I also confirmed one last area of rust that has to be fixed... It seems like there is still so much to do before it goes off for media blasting and paint next week... hopefully...
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055505
09/09/11 01:37 AM
09/09/11 01:37 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The black coating you are seeing is the dip coating that the body was immersed in, the rocker blackout and inner fender blackout was applied later and is a different in that it's paint and not dip sealer/primer, and the shade of black is different.
When I steam cleaned my 8.75 rear end I not only found the "A" but MANY other markings and ink stamp details that were invisible before I removed some of the grease and rust. Mine looked similar to yours, a fine rust patina all over it which hid a lot of details, most of that wipes right off with a rag and water. If you clean it don't just have someone sand blast it, etc. go nice and slow using the mildest cleaners possible gradually progressing to more aggressive stuff so that you don't accidentally errase some hidden inspection marking details.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055506
09/09/11 02:17 PM
09/09/11 02:17 PM
owt west
Thread Ender1 Offline
owt west
Here are some markings i found on my diff, if anyone is interested.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: Thread Ender1] #1055507
09/09/11 03:48 PM
09/09/11 03:48 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks SB Duster!! I appreciate the pic, as it will help me to locate the markings on mine. Any other pics you have will be welcomed.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055508
09/09/11 05:30 PM
09/09/11 05:30 PM
owt west
owt west
heres a few more..
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: Thread Ender1] #1055509
09/09/11 05:33 PM
09/09/11 05:33 PM
owt west
owt west
This also has the side ways A , you can bearly see it but it is there. I assume they might of hung them from end to end at the plant like a dry cleaner?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: Thread Ender1] #1055510
09/09/11 10:54 PM
09/09/11 10:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Great pics SB! There should also be some paint markings on the center section, near the casting numbers and along the flat beam on the bottom, various splotches were gear ratios, assembly date codes, etc.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055511
09/16/11 10:55 AM
09/16/11 10:55 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I got a lot of progress done yesterday. I spent a good part of the day fabbing up and welding my rotisserie mounts. Then I was able to get the driveline out. More pics to come today.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055512
09/16/11 01:36 PM
09/16/11 01:36 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Nice work.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: CDN72SE] #1055513
09/16/11 11:10 PM
09/16/11 11:10 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks!
I got the rotisserie mounted in the front and rear today, but its not ready to flip yet. I'm hoping to drop the rear end and springs out tomorrow.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055514
09/17/11 12:28 PM
09/17/11 12:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Looking good!
Be careful to measure the centerline hieght for clearance before rotating it. Also be sure the doors, hood and trunk lids are wired closed or you could get a nasty surprise when gravity takes over!
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055515
09/27/11 10:06 PM
09/27/11 10:06 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Finally got time to get it flipped on the rotisserie today. I had to fab an extension that connects both halves, which took more time than I wanted. I was able to completely pressure wash the Duster front to rear. I also got the front clip removable and was able to drill some small inconspicuous alignment holes in key areas. All of the black stripes came off and made it look like red on red stripes. Nothing too notable came from washing, other than a "Hamms Beer" churchkey down in the pass fender. Its ready to go to the media blaster finally!!
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055516
09/27/11 10:07 PM
09/27/11 10:07 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres a pic of the black underside by the gas tank / shock area.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055517
09/27/11 10:10 PM
09/27/11 10:10 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres the rest of the underside. Nothing dramatic jumped out detail wise, other than the trans tunnel having a lot of black in it.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055518
09/28/11 09:34 PM
09/28/11 09:34 PM
midwest
68427vette Offline
68427vette  Offline
midwest
was this the car that was on ebay a while back???? cool car.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: 68427vette] #1055519
09/29/11 10:12 AM
09/29/11 10:12 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Yes it was on ebay back in Jan, and discussed on here.
Its loaded on the trailer and ready for its date at the media blaster.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055520
09/29/11 10:23 AM
09/29/11 10:23 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
What are you gonna do to the motor?
