71 cuda drive line #1055186
08/17/11 10:52 PM
08/17/11 10:52 PM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
do u buy a drive shaft used or can u get the correct one made some where thanks
Re: 71 cuda drive line [Re: GardnersGotCudas] #1055187
08/27/11 04:27 PM
08/27/11 04:27 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Nick,
Going back through the posts and saw this one went unanswered so...If originality is'nt a factor then go for the new one... Until you track down an original,buy it, then have it spun{balance/bend check} you'd have the new one in hand...Do you have the trans yoke ??? What size u-joints is the rear set up for ??? A new shaft will be one less headache on the project....
