Crank selection for boost #1054525
08/17/11 01:09 AM
08/17/11 01:09 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
For all you guys out there that have/are built large cu in (540/572) with either supercharged or turbo, what crank are you running. Output probably in the 1200-1400 HP range?
I want to build the motor to be reliable and not overpower the internals.
I'd rather pay now and do it right. Budget for the rotating assy is about $3,500.
Re: Crank selection for boost [Re: Chargerfan68] #1054526
08/17/11 01:55 AM
08/17/11 01:55 AM
That money ain't going to get you relaible parts at that power level Call Crower, Calles(SP?), Sonny Bryant and any other good drag race crankshaft company and ask them about which crankshaft and price for that power level Going turbo may lower the costs on the crank and rods, maybe not as I have not built a turbo motor at any power level yet
Re: Crank selection for boost [Re: Chargerfan68] #1054527
08/17/11 02:01 AM
08/17/11 02:01 AM
AndyF Offline
AndyF  Offline
Better raise the budget to $4500. Callies crank, Oliver BBC rods and Diamond pistons should get you there.
Re: Crank selection for boost [Re: AndyF] #1054528
08/17/11 09:18 AM
08/17/11 09:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what I was thinking... I bought a Callies crank
and they said that it was good to 1200hp for the
model that I got and that was like $2200 for just
the crank
Re: Crank selection for boost [Re: MR_P_BODY] #1054529
08/17/11 10:25 PM
08/17/11 10:25 PM
New York, USA
New York, USA
OK, I will just need to recalculate the budget some. I need to wait longer to get the other parts.
Mr. Pbody, what Callies line did you go with the Magnum, XL, dragonsl.? I was also looking at Ohio cranks.
Thanks for the feedback guys.
Re: Crank selection for boost [Re: Chargerfan68] #1054530
08/17/11 11:19 PM
08/17/11 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I forget what it is... but it wasnt the dragon slayer
might be the XL
Re: Crank selection for boost [Re: MR_P_BODY] #1054531
08/18/11 08:25 PM
08/18/11 08:25 PM
New York, USA
New York, USA
might be the XL
Thanks Mr. Pbody. That is a nice crank. They don't list the XL for Mopars, but I guess they could custom make it for you.
I am going to call them to talk next week .
Thanks...and any other advice. Don't know if I should buy parts separate, or (for ex.) Ohio has the rotating assy complete from them. I have read that with these good cranks, you have to be careful where and how crank is lightened and balanced. Some say to have the manuf. do it...so to get the entire assy from them may be beneficial.
What do you think??
Thanks.
Re: Crank selection for boost [Re: Chargerfan68] #1054532
08/18/11 09:10 PM
08/18/11 09:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you think??lance
Thanks.
Myself I would have the manu do the lightening and
if you know the bob weight have them do the balance
BUT I would still have the balanced checked but
thats just me
Re: Crank selection for boost [Re: Chargerfan68] #1054533
08/18/11 09:46 PM
08/18/11 09:46 PM
If your going to run a crankshaft driven supercharger you might want to run one with center counterweights I don't think Ohoi Crankshaft company makes any center counterweighted crankshafts I wouldn't consider a new billet crankshaft either at your desired HP goals A good forged steel center counterweighted crankshaft is great with a roots type supercharger or a crankshaft driven centrifigul(SP) supercrharger
Re: Crank selection for boost [Re: Cab_Burge] #1054534
08/18/11 11:20 PM
08/18/11 11:20 PM
New York, USA
New York, USA
Thanks Cab,
Just curious, what is the reason the center countwt. shaft is better for the belt dr. superchargers? Anything to do with the load on the snout of the crank due to the supercharger pulley, or more in depth than that. I'd like to know.
Thanks again for the info,
Greg.
Re: Crank selection for boost [Re: Chargerfan68] #1054535
08/19/11 02:29 AM
08/19/11 02:29 AM
I can't give you a good reason other than I have been told by racers I trust that build a lot of supercharged Hemi to make sure and use a fully counterweighted crankshaft if your going to rev it up(past 6000 RPM) and make more than 7 to 12 lbs of boost regularly I've only built two blown gas hemi motors, one had a full counterweighted crank and the other didn't. The non couterweighted crankshaft motor was for a customer who owned several Dodge and Chrysler dealerships and he already had the crank, the second customer wanted a motor that would have all the best parts in it, he didn't want to take any chances of blowing the motor up and hurting the car If you look at the non versus one with counterweights you'll see that the counterweighted crank probally is stronger in the middle
Re: Crank selection for boost [Re: Cab_Burge] #1054536
08/21/11 12:12 AM
08/21/11 12:12 AM
New York, USA
New York, USA
Thanks Cab.
Does anybody know why the typical cranks have more counterweight toward the ends and not in the middle. I know there is an engineering reason and I am curious.
Thanks,
Greg.
