Re: How would you go about fixing this hack job?
[Re: six-pack-mopar]
#1054206
08/16/11 09:04 PM
08/16/11 09:04 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
looks like alighnment wasn't their worry. Id probably cut it off again and start from scratch. you could maybe reuse the roof skin if it isn't butchered too bad, otherwise, AMD sells skins. as always, when your redoing it, always prep the area as best as you can before you weld the skin back on.
btw, roof skins really arn't that bad. Id say a lot easier to do than a 1/4 panel.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#1054208
08/16/11 09:12 PM
08/16/11 09:12 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
I already figured I would be doing the roof skin and full quarters that's not realy the problem. The issue is that they cut through the roof frame. Would it be structuraly ok to butt weld the roof structure at the c piller and a pillars?
BTW it's a R/T car 440 auto pp1 red, black top interior and stripe so I feel it's worth a little effort to try and save it.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
[Re: 69charger440_6pa]
#1054210
08/16/11 09:43 PM
08/16/11 09:43 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Are you saying that instead of skinning the roof they cut it all the way through the A and C pillars? Then welded it back together?
[Re: RodStRace]
#1054214
08/17/11 01:05 AM
08/17/11 01:05 AM
69charger440_6pa
Oakley CA
[quote Get all the rust off, deskin it, weld all the past sins up and install new skin. Boy, that was easier to type than it will be to do....
Those were my thoughts on the issue. I guess what I'm worried about is the strength of the c-pillar and a-pillar being butt welded, but hot rod guys do that all the time.... Same concept as chopping the top.
[Re: wicked]
#1054217
08/17/11 11:01 AM
08/17/11 11:01 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
dang. if they cut all the way through the pillars and welded an entire new roof on that way...i would spit the roof panel from the frame structure, fix the frame structure by itself, adding reinforcement plates over the joints as needed and doubleing the welds, doing lots of tack welds till you have a continuous welded seam. then toss the skin back on. and add subframe connectors for insurance I'm probalby going to be pulling the skin off my Cuda soon. I'm neck deep in a quarter panel replacement right now, and I'm in the process of fixing all the soft spots under the quarter. the other day though, I needed motivation. I tossed the quarter in place, and thought it looked great. I can't wait to get it done now! I'm not after a 100 point restoration show car. I'm just killing the rust, and building a structurally sound, good looking cruiser/driver.
**Photobucket sucks**
#1054218
08/17/11 12:12 PM
08/17/11 12:12 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
But those chopped top cars are on full frames , not unibodies where the roof is part of the structure.
#1054219
08/17/11 12:16 PM
08/17/11 12:16 PM
Morty426
Sacramento CA
Yes that's exactly what was done.
I've had a lot of Chargers and torsional ridgidity is not their strong suit. If it was me I'd fix it right if the car was worth it. The big problem is you need to make sure the car is true.
I would peel it back like an onion. I would remove the quarters and the old roof. Build a brace to hold the car in a true position and then rebuild the roof understructure with good pieces. Then fit new quarters and roof skin - then spot weld or plug weld them on.
This is not an amatuer job.
Good luck.
[Re: Morty426]
#1054220
08/17/11 06:18 PM
08/17/11 06:18 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
buy all new metal from AMD.
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 72N96RR]
#1054221
08/17/11 07:45 PM
08/17/11 07:45 PM
Morty426
Sacramento CA
And then hope it fits
[Re: Morty426]
#1054222
08/17/11 09:35 PM
08/17/11 09:35 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
Just how well do the AMD Charger roofs and quarters fit? Also wondering about the rear deck filler panel fit.
[Re: JohnRR]
#1054223
08/18/11 01:20 AM
08/18/11 01:20 AM
Posts: 4,230 State of retirement
52savoy
State of retirement
I've seen first hand what happens when the pillars are cut through without a jig. The unibody springs out of shape and getting it back is almost impossible. Get a frame chart and put it on a jig before even starting. Jigs are available for a reasonable price....
http://www.accessiblesystems.com/subframe/subframe.php
hopefully the front and back glass openings weren't screwed up to much.
