fan shroud kung foo #1051170
08/11/11 03:15 PM
08/11/11 03:15 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
Hi,
I'm looking for ideas on using a modern fan shroud with electric fans on my 26"x17.5" BB radiator. I know most modern cars come with an electric fan (or two) and I know people have done what I'm trying to do. What I need are specific examples of a particular fan/shroud combination that fits a B body with a 26" radiator. So like, if you know a fan shroud combination from a 2003 Dodge Minivan worked for you, that's what I want to know. Once I know what types fans/shrouds are in the ball park, I can hit the local junk yards looking for a suitable setup.
Thanks,
Joe
P.S. I realize I can buy a new aluminum shroud with fans from Jegs or Mancini. I'm trying to save a few bucks and see if I can find a cheap alternative.
Re: fan shroud kung foo [Re: preddy] #1051171
08/11/11 03:22 PM
08/11/11 03:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
https://board.moparts.org/ubbthreads/show...part=1&vc=1
One of the members is working on a variable speed fan controller specifically for these fans. Due to their design you can't use the normal controllers.
- Stu Harmon
Re: fan shroud kung foo [Re: feets] #1051172
08/11/11 03:43 PM
08/11/11 03:43 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
That's what I'm talking about. That's great information. Thanks! I'm running a modern GM style alternator that really cranks so I'm pretty sure it can handle that fan.
