Re: '55-56 Dodge late-model V8
[Re: dynamite]
#1050594
02/17/12 07:51 PM
02/17/12 07:51 PM
Posts: 84 Ontario, CANADA
hemi pwr
Ontario, CANADA
Hi do you guys have any good ideas or pictures of how to put a 1970 440 motor and 3 peed auto 727 tranny in my 1958 plymouth it has a flathead six in it ...so im not sure whats the best way to put in the 440...thanks for any info Les
1970 440-6 Cuda
71 duster
1999 Dodge ram diesel dually
1958 plymouth hardtop
1975 Fury 2 door
1970 AAR cuda clone
[Re: hemi pwr]
#1050595
02/21/12 01:02 PM
02/21/12 01:02 PM
Posts: 3,490 Buckeye Lake
56_Royal_Lancer
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Les, the '58 is a different animal from my '56, so I have nothing for you. There are a few guys on www.forwardlook.net that have done the swap, you may want to check there, too.
[Re: 56_Royal_Lancer]
#1050602
03/05/12 11:33 AM
03/05/12 11:33 AM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Well, the 440 & 727 are in, used a set of off-the-shelf Hedman headers, plenty of clearance. Did not need to modify trans. tunnel or the heater box, both of which I expected to do. Working on details right now (throttle linkage, wiring, etc.) Moparts member 66net500 fabbed up really cool motor mounts and modified the stock trans. crossmember. When I have the job done I'll start a new thread w/ photos, measurements & part #s for anyone interested in trying this. Can't wait to do a little
Very interested in this info
[Re: THE GLASS MAN]
#1050604
06/03/12 11:48 AM
06/03/12 11:48 AM
Posts: 1,019 Finland
mafo
Finland
I have mine finally running, 318 magnum/ rh42/ dana 35 jeep zj disc brakes all around http://s1083.photobucket.com/albums/j382/mafo1/?action=view¤t=CIMG2257.mp4
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1050608
06/12/12 04:11 AM
06/12/12 04:11 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
very kool what did you use as a donor ??did you use the entire donor wiring ? and computer ?
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#1050609
06/12/12 06:58 AM
06/12/12 06:58 AM
mafo
Finland
engine is from a 93 grand cherokee, as is most of the wiring, computer is a mopar perf 92 dokota, trans is from a van I believe and the rear is also from a grand cherokee( for the disc brakes), prop shaft is from a early A body, bolts right in Then I found some different wiring schematics on the web and started sorting it all out, used a relay/ fuse box from a jeep of the same age, everything works, even the cruise control
