Re: Painting a K member. What to use?
[Re: Jim_Lusk]
#1048859
08/07/11 11:31 PM
08/07/11 11:31 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
por 15 semi gloss . its omly as good as the prep my 69 charger has it for 6 years now . just did my 74 charger this spring .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: dogdays]
#1048865
08/09/11 12:30 PM
08/09/11 12:30 PM
Challenger 1
Cincinnati, Ohio
That's a good idea but rock chips may be harder to fix. Anyone remember Imron? It was developed for truck chassis. Hard to touch up, although I can recall when it was THE paint for show cars.
R.
Bed liner?
My 74 challenger has Imron paint on it from 1984, has held up very well. Like what was said, prep is more important that what paint.
IMO I would not dip it because it will make it very hard to clean out all the acid because of the way there welded togeather. I have had great durability by blasting and painting with Eastwood Chassis Black, that's some good stuff out of a spray can.
I have got one that I did over 10 years ago with reg Eastwood Chassis black and is holding up great. I have another that I did 6 years ago that is even better. No reason to powder coat and have it rust inside from dipping. My Poweder coating is easily missed in tight places and then will rust quickly.
[Re: Challenger 1]
#1048866
08/09/11 12:35 PM
08/09/11 12:35 PM
RapidRobert
Does Eastwood (or anyone else) have a good chassis spray in any other color? Want to do some wheels in red
[Re: RapidRobert]
#1048867
08/09/11 01:49 PM
08/09/11 01:49 PM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Chemical dip and "acid" are two different things. Hot tanking is not an issue.
