Holley 4150 HP Won't Idle Down #104861
08/14/08 04:08 PM
08/14/08 04:08 PM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
I can't seem to get my Holley 4150 HP carb to get below 1100-1200 rpm.
Idle speed screw is backed off all the way. Is there another idle screw or ?
Thanks!!
Re: Holley 4150 HP Won't Idle Down [Re: ResQ911] #104862
08/14/08 04:13 PM
08/14/08 04:13 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
there is the secondary idle screw that you can only get to from the bottom when the carb is off.
Re: Holley 4150 HP Won't Idle Down [Re: ResQ911] #104863
08/14/08 04:50 PM
08/14/08 04:50 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Before you remove the carb and try for another adjustment, is the throttle arm making a full forward return while at idle? Remove the throttle cable and see if the throttle arm moves forward any.
Re: Holley 4150 HP Won't Idle Down [Re: 68Bullit] #104864
08/14/08 08:01 PM
08/14/08 08:01 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
also try the kickdown rod to make sure it isnt getting hung up
Re: Holley 4150 HP Won't Idle Down [Re: 68Bullit] #104865
08/14/08 10:06 PM
08/14/08 10:06 PM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
Tried the throttle lever and no kick-down.............4-speed
Re: Holley 4150 HP Won't Idle Down [Re: ResQ911] #104866
08/14/08 10:21 PM
08/14/08 10:21 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
vacuum leak.............
Tony
70 AARCuda Vitamin C
Re: Holley 4150 HP Won't Idle Down [Re: 70AARcuda] #104867
08/15/08 09:46 AM
08/15/08 09:46 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
does that model have a choke? if so check that the choke linkage isnt hanging up (fast idle)
Re: Holley 4150 HP Won't Idle Down [Re: chrisf] #104868
08/15/08 02:03 PM
08/15/08 02:03 PM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
No Choke
Re: Holley 4150 HP Won't Idle Down [Re: ResQ911] #104869
08/15/08 03:22 PM
08/15/08 03:22 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
there is a vacuum port out the back of the baseplate for PCV or brakes, make sure that is plugged off or if it is being used than you are good.
Re: Holley 4150 HP Won't Idle Down [Re: Viol8r] #104870
08/15/08 10:01 PM
08/15/08 10:01 PM
Eau Claire, WI
ResQ911 Offline OP
super gas
ResQ911  Offline OP
super gas
Eau Claire, WI
No vacuum port either.
Re: Holley 4150 HP Won't Idle Down [Re: ResQ911] #104871
08/15/08 10:12 PM
08/15/08 10:12 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
another vote for a vacuum leak
Re: Holley 4150 HP Won't Idle Down [Re: 493_DART] #104872
08/16/08 12:59 AM
08/16/08 12:59 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
spray carb cleaner down the air bleads. Make sure they do not have any dirt in them... They will cause you not to get the thing to idle or
