Re: Need help with paint boot venting
[Re: 73rrak]
#1048307
08/07/11 02:05 AM
08/07/11 02:05 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
I paint quite a bit with a box fan 20 inch bolted in the side door opening and the door opening carborded up to the fan . i just suck out the over spray and use a hvlp guns and it works fine . i have a friend who does paint less dent work all over the area and he says my work is just as good if not beter than all the big paint and body shops do with million dollar booths . Its all in the prep , i also like to wipe the paint work off with anti static , and auto body tack rags (low tac) before base and after base & before clear . This seams to help with dust .
1969 Dodge Charger
1969 Dodge Superbee
[Re: Kern Dog]
#1048309
08/07/11 06:12 PM
08/07/11 06:12 PM
Posts: 1,121 State, country, etc.
gss
Thanks for the replies, after doing a lot of research, I may be leaning towards doing a negative pressure booth. It seems the big issue is the size of the inlet. A small inlet with a lot of air moving through it, ie a fan, will cause a lot of turbulence in the booth. I think using the fan at the exhaust opening and 2-4 large furnace filters for the intake will work much better.
Now I need to figure out some way to insulate the exhaust vent when not in use so the Minnesota winter air doesn't get in.
[Re: gss]
#1048310
08/08/11 02:53 AM
08/08/11 02:53 AM
Posts: 1,744 Phila
PhillyRag
Phila
Hello,
I will have a 20' x 25' stall in my new garage that will double as a paint booth. I prefer to have positive pressure venting with a blower on an interior wall blowing in and a vent on the outside wall for exhaust. typically preferred; don't have to worry about fumes/overspray passing thru the fan.
Would 1500-2000 cfm would be adequate? For that size area, seems adequate.
Has anyone bought a blower for this purpose that you are happy with? Where did you get it? How about a shutter type vent for exhaust? I am hoping for something better than the Menards/Home Depot stuff.
Also, what height would be optimal for the fan and exhaust? I would think the fan should be high and the exhaust should be low. agree with that. They will have to go on the side walls, not the end walls. How far from the end walls should they be?
Thanks!
No windows you can use? Garage door: position a sheet of plywood between floor & door lower edge; cut some openings & mount some home heater filters for the exhaust.
