alcohol & intake #1047403
08/05/11 02:06 AM
08/05/11 02:06 AM
florida dade
cesar perez Offline OP
florida dade
running on alcohol is their an advantage running a sheetmetal tunnelram over a cast tunnelram
Re: alcohol & intake [Re: cesar perez] #1047404
08/06/11 01:09 PM
08/06/11 01:09 PM
gregsdart Offline
gregsdart  Offline
That all depends on how good the cast Item is. If it is real close to your combo in runner size, plenum, etc, you won't see a lot of difference. The old tunnelrams for mopar BBs were small runner, and responded to porting. If you are building an indy head motor, or B1 deal, the cast Indys work pretty good,same for the B1.
There is always room for improvement, just a matter of budget and where you want to spend money. A custom manifold is way down my list of what to do next, as the 3x single four I run is pretty good as is. Put a 2100 cfm terminater on it, and there shouldn't be much improvement. I have ported 440-1 heads, 528 cubes.
Re: alcohol & intake [Re: gregsdart] #1047405
08/06/11 01:22 PM
08/06/11 01:22 PM
ky
68roadrunner Offline
ky
with fuel injection the intake is just for air, the intake is alot more important with a carb, air speed,fuel suspension and such. in my opinion.
Re: alcohol & intake [Re: 68roadrunner] #1047406
08/06/11 06:45 PM
08/06/11 06:45 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I had my Indy Tunnel-Ram ported to make sure the runners were all equal.
I'm running Terminators on mine.
A better question might be is the sheet metal intake worth the extra $$$.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: alcohol & intake [Re: 68roadrunner] #1047407
08/07/11 07:12 AM
08/07/11 07:12 AM
gregsdart Offline
gregsdart  Offline
Good point. I would think though that a well built sheetmetal TR would gain some from two sources over what I have. One would be a slight improvement in air density due to about half the vacuum, which would be a small amount going from one to two Terminaters. The other would be a small gain from better cylinder fill from a custom designed runner.
Re: alcohol & intake [Re: gregsdart] #1047408
08/07/11 02:05 PM
08/07/11 02:05 PM
ky
ky
any time you can gain in cylinder fill it will help.
the op did not say if he was injected or carbed . like was said depends on how good the cast unit is will decide how much better a fab will be.
a custom intake properly design can cut back on the reversion and the reverse pulses of the intake closing, which might help a carb setup more than injection, but would help inj. also
Re: alcohol & intake [Re: 68roadrunner] #1047409
08/08/11 03:17 AM
08/08/11 03:17 AM
Mesa, Arizona
az426hemi Offline
az426hemi  Offline
Mesa, Arizona
I intake as much alcohol as I can.
Not sure that it is much help though.
Mike Firestine
mefirestine@yahoo.com
