Colder Plugs? #1045581
08/02/11 01:55 AM
08/02/11 01:55 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I pulled all the plugs this week and noticed, on 3 plugs, the tips of the insulator/porcelain were starting to flake off. Did not seem like a total plug failure but small flakes missing. Also did not see any specks from detonation. Am I wrong in thinking I may be running to hot of a plug? The base of the porcelain looks a bit lean but not too bad.
11:1 Stealth headed 440
EFI
Currently run an NGK BCPES-6 plug.
I have some NGK with a colder 7 range in the shop. Just wanted to verify that the plug heat range may be causing this.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Colder Plugs? [Re: Viol8r] #1045582
08/02/11 03:16 AM
08/02/11 03:16 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
EFI
thats a pretty hot plug most i know run a 8 or a 9
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Colder Plugs? [Re: Stroker Scamp] #1045583
08/02/11 09:52 AM
08/02/11 09:52 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I would put the -7s in.
Re: Colder Plugs? [Re: sixpackgut] #1045584
08/02/11 11:31 AM
08/02/11 11:31 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Thanks, I will put the 7's in and check them. Maybe go to -8's if I still signs of them being too hot.
Re: Colder Plugs? [Re: Viol8r] #1045585
08/02/11 12:32 PM
08/02/11 12:32 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
FWIW I run non-projected tip NGK 9s in my Stealth heads with 13:1.
Re: Colder Plugs? [Re: PolyDart] #1045586
08/02/11 02:25 PM
08/02/11 02:25 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Saw this link the other day on "How to read Plugs' , thought it was quite handy
http://www.dragstuff.com/techarticles/how-to-read-plugs.html
Re: Colder Plugs? [Re: mopar_mark] #1045587
08/02/11 03:28 PM
08/02/11 03:28 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Saw this link the other day on "ow to red Plugs' , thought it was quite handy
I have read this before and it is good information. The ground strap has minimal color change and the porcelain is showing signs of damage/stress, so I think I am on the right track with the colder plug.
Re: Colder Plugs? [Re: Viol8r] #1045588
08/02/11 03:41 PM
08/02/11 03:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the ngk 7`s on the street and race wthe 8`s at 12.1 comp. and rpm heads.
Re: Colder Plugs? [Re: Thumperdart] #1045589
08/02/11 04:44 PM
08/02/11 04:44 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Thumper.....looking at your sig, you got thing movin' out! Nice job. Watched a street driven, all steel, all motor Nova run an 8.80(in the 1/4) last weekend....nuts.
Re: Colder Plugs? [Re: Viol8r] #1045590
08/02/11 06:41 PM
08/02/11 06:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My car`s a turd by comparison but still a fun street car. I know of a few 8-second street cars but ALL of em run power adders so not as special to me as n/a stuff.
