quick question #1045522
08/02/11 12:34 AM
08/02/11 12:34 AM
long island newyork
Abodyjohn88 Offline OP
long island newyork
do you guys see a problom with runnin 9.2-1 compression with iron heads with no intercooler, but meth injection on 93 pump gas and running it up to 15-20 psi??? kepp in mind this is mainly a street car. looking to make around 600whp with a paxton novi1200.... also with the novi1200 kit its comes with a box that encloses the whole carburator and pressurizes it, do i still need a blow thru carb??
oh yea, 410 inch smblock, forged assembaly, stage 3 ported x heads, hyd roller .575 lift, eddy victor intake, tti step headers.
Re: quick question [Re: Abodyjohn88] #1045523
08/02/11 01:27 AM
08/02/11 01:27 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
You're basically doing the same thing as I am planning on doing. Mine is 9.3:1, non-IC, E85. I won't run as much boost as you, but you'll have no problems doing it.
Meth is good stuff, even better then E85. I know that the turbo guys just ABUSE their stuff on E85, so you should be fine.
No you don't need a blow through carb if you have a box. I just don't know how great the box really works. That's definately an old school approach.
Re: quick question [Re: Abodyjohn88] #1045524
08/02/11 01:44 AM
08/02/11 01:44 AM
long island newyork
long island newyork
this is what the paxton kis looks like with the enclosure for the carb
Re: quick question [Re: Abodyjohn88] #1045525
08/02/11 05:59 PM
08/02/11 05:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think 15 may be 17 pounds at the most but you would want to watch for detination.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
