BB Oil Pump Cover #1045429
08/01/11 10:45 PM
08/01/11 10:45 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Whom makes an oil pump cover that will allow the use of a remote oil filter with a World Block?? The Muscle Motors unit seems to be only for use with an oil filter.
Alan
Alan Jones
Re: BB Oil Pump Cover [Re: LA360] #1045430
08/01/11 10:50 PM
08/01/11 10:50 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have a Milodon on mine. Melling pump Milodon cover. Brand of block has nothing to do with it.
Re: BB Oil Pump Cover [Re: rowin4] #1045431
08/01/11 11:05 PM
08/01/11 11:05 PM
LA360 Offline OP
LA360  Offline OP
The World blocks have an inlet/outlet already, I thought it pertinent to mention it. Worst case I will machine one up if I can't find something that suits.
Alan Jones
Re: BB Oil Pump Cover [Re: LA360] #1045432
08/01/11 11:27 PM
08/01/11 11:27 PM
rowin4 Offline
rowin4  Offline
I have a World block, you can use a stock pump or aftermarket one with or with out the remote filter. On the world block you can just plug the external pickup hole in the front of the block depending on the pickup used.
Re: BB Oil Pump Cover [Re: LA360] #1045433
08/02/11 11:44 AM
08/02/11 11:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That port at the front is an inlet from the pan only - it would replace the Milodon spacer in a dual-line configuration or it would be used if you were blocking off the internal pickup.
You could use either the old Milodon cast "remote filter" cover or their new billet one. Or you could use the Muscle Motors or Milodon covers and screw on a remote filter adapter.
You make it sound like you're the first person to use a world block with remote filters !!!
