#1043592 - 07/30/11 09:49 PM 440 crank?
Lawn Monkey Offline
Loc: USA
70, 440 crank is there an automatic crank and a manual crank or just one standard crank
#1043593 - 07/30/11 10:18 PM Re: 440 crank? [Re: Lawn Monkey]
bumps440 Offline
super gas
Loc: Westbury, NY
Chrysler motors usually were not drilled for a pilot bushing. How many chrysler imperials did you know with a 4 speed!
Now ask me how I know that.
Built my first engine back in 74 for my GTX. got a junkyard 440 to build. engine all done on the engine stand and now its time to install the pilot bushing.......NOT.
446ci Iron heads, 3240lbs, Footbraker best et 9.84 @ 134.90 at sea level
#1043594 - 07/31/11 03:06 AM Re: 440 crank? [Re: bumps440]
Lawn Monkey Offline
Loc: USA
bumps440 good post as would have it I have a Chrysler Newport 440 as my base for my build. I assume its just a little machine shop work to install a pilot bushing?
#1043595 - 07/31/11 05:23 AM Re: 440 crank? [Re: Lawn Monkey]
JohnRR Offline
Loc: U.S.S.A.
It may be that simple , if the shop can handle the job . the cranks are drilled but not finished reamed to size and or depth . the simple way around it is to use the late model pilot bushing that fits in the crank register where the torque convertor snout sits. you may more than likely need to trim about 3/8" off the end of the input shaft , easy to do wit ha whizzer wheel just cover the trans well and wrap tape around the end of the bearing retainer to keep that area clean.
Napa used to sell a bearing that would fit the unfinished cranks but the time I tried to buy one it was not the correct part ???
#1043596 - 07/31/11 06:25 AM Re: 440 crank? [Re: Lawn Monkey]
bumps440 Offline
super gas
Loc: Westbury, NY
Yes It is easy enough to do now with the crank out of the motor. there is a hole there but not the right size. easy machine shop job now.
#1043597 - 07/31/11 07:47 AM Re: 440 crank? [Re: JohnRR]
joewhite440 Offline
Loc: Western Pa
BCA/National FC69907 is the number and I paid $12 for the last one I got. Passon's and Brewer's have a bearing also $18.
My 72 440 was out of a Big Chrysler, Steel crank and it was drilled for the regular bushing. I thought most Steel Cranks were? I know the Cast ones are not unless they are out of something with a 4-speed.
#1043598 - 07/31/11 11:55 AM Re: 440 crank? [Re: bumps440]
DaytonaTurbo Offline
Loc: Manitoba, Canada
Depends on the crank. My cast 440 crank is not drilled at all.
#1043599 - 07/31/11 12:10 PM Re: 440 crank? [Re: DaytonaTurbo]
therocks Offline
Its Lost
Loc: Niles , Ohio
Ive got a Imp crank in my 440.It was drilled.It seems they were hit and miss.Some are some arent behind autos.Like said crank out its an easy fix.Rocky
Chrysler Firepower
#1043600 - 07/31/11 04:26 PM Re: 440 crank? [Re: therocks]
John_Kunkel Offline
Loc: Rio Linda, CA
Don't confuse "drilled" with drilled to the correct size, most all forged cranks were drilled .915" but not all were finish sized .938" for a bushing.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
25,493 Registered Members
193,101 Topics
Dana rear option
by 2abodymcodes
2 minutes 57 seconds ago
Holley metering blocks
by Old School
44 minutes 26 seconds ago
Can anyone point me to fluid flow schematics for 727?
by BradH
54 minutes 1 second ago
73 Barracuda Creature Comforts issue
by BcudaChris
Today at 12:47 PM
