Z Bar for 67 B Body with 11 inch bellhousing #1041789
07/27/11 11:11 PM
07/27/11 11:11 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
I need a new Z Bar for my 67 B Body. My old one has the lower bracket welded 1 1/4 inches from the end of the tube, and the one that PG just sent me has the lower bracket welded 3/4 of an inch from the end of the tube. This car has not been together since I have owned it so just want to know if the one I have is correct. I am using a 11 inch bellhousing.
thanks
Re: Z Bar for 67 B Body with 11 inch bellhousing [Re: hemi67] #1041790
07/28/11 09:50 AM
07/28/11 09:50 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Good chance the arm will hit the bellhousing. Is the tube 9" long?
Here is the correct part for 11" bell in a B-body:
http://www.brewersperformance.com/proddetail.asp?prod=TS914
You can see the difference in the E-body one with the smaller 10.5" bellhousing here:
http://www.brewersperformance.com/proddetail.asp?prod=TS913
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Z Bar for 67 B Body with 11 inch bellhousing [Re: 64dodge572] #1041791
07/28/11 11:29 PM
07/28/11 11:29 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks Dan. ordered one today.
