Re: Fuel Injected Slant Sixes?
[Re: MuuMuu101]
#1039415
07/25/11 12:08 AM
07/25/11 12:08 AM
Posts: 5,993 Salem
Grizzly
Moparts Proctologist
Salem
Yes. The 4.0 Jeep injection can be modified and used on a slant six.
Mo' Farts
Moderated by "tbagger".
[Re: patrick]
#1039420
07/26/11 08:45 PM
07/26/11 08:45 PM
DaytonaTurbo
Manitoba, Canada
One of the guys at diyautotune.com has a megasquirt on his slant 6. You could do it for pretty cheap if you threw an 80's/90's GM V6/V8 TBI throttle body onto a 2bbl slant 6 intake. Would just need to buy or make an adapter to get them to bolt together.
fuel distribution due to differing runner lengths is the slanty's biggest issue. I wouldn't go to EFI unless I went to MPI. I'd probably JY it, taking a setup off of a 3.8L GM and adapting it.
I have heard stories of guys picking up some good hp and mileage from going to port efi on a slant 6 because of poor fuel distribution on a stock intake. However if you just wanted an increase in driveability, a tbi system could be rigged up on the cheap.
[Re: MuuMuu101]
#2357925
08/22/17 12:52 AM
08/22/17 12:52 AM
Posts: 6 Mohawk Valley, Oregon
knote72
I was curious about this topic as well. Somewhere down the road I wanna do a Turbo EFI slant in a pickup, and would prefer a MPFI setup if at all possible. I came across this article DeBiase EFI for adapting the GM 3.8L MPI setup. I was curious about the Jeep 4L route, because I have a 92 Grand Cherokee with a 4L that is just sitting on my property and would like to find out if I can use that setup instead
[Re: MuuMuu101]
#2357944
08/22/17 01:17 AM
08/22/17 01:17 AM
Posts: 22,695 Bitopia
jcc
Bitopia
I was just tossing up the idea for when I get an automatic car in the future (granted I am driving in traffic). Basically my only thing is trying to get a little bit better fuel efficiency and better cold starts. I understand, I'm in a EFI turbo slant build right now. But in all honesty if I started over, a hot turbo 2.2 is the better choice, IMO A problem I am told and I addressed, efi on an alum intake has potential for injector heat soak, mainly on start up, with nearby exhaust
[Re: knote72]
#2358076
08/22/17 12:45 PM
08/22/17 12:45 PM
DaytonaTurbo
Manitoba, Canada
I was curious about this topic as well. Somewhere down the road I wanna do a Turbo EFI slant in a pickup, and would prefer a MPFI setup if at all possible. I came across this article DeBiase EFI for adapting the GM 3.8L MPI setup. I was curious about the Jeep 4L route, because I have a 92 Grand Cherokee with a 4L that is just sitting on my property and would like to find out if I can use that setup instead 6 year old thread, but... you can use the Jeep 4.0 in a truck. In a car the deck height might be a problem if you enjoy being able to close your hood. If you are keeping it stock, the Jeep efi system is easy enough to dissect and transfer over. Transmission selection would rule out stock mopar transmission however there are other swap options that would work.
[Re: DaytonaTurbo]
#2358144
08/22/17 03:42 PM
08/22/17 03:42 PM
Posts: 5,993 Salem
Grizzly
Salem
Has already been covered and has a video attached in the first reply in case you missed it.
Mo' Farts
[Re: MuuMuu101]
#2358410
08/23/17 12:55 AM
08/23/17 12:55 AM
Posts: 20,149 Park Forest, IL
slantzilla
Park Forest, IL
I helped a buddy build an EFI system on his 68 Barracuda. He used a Mega Squirt box, S-10 Blazer throttle body, a Clifford intake, and the in tank pump setup. (Welborn maybe)
He bought the tool for doing the injector bungs and fuel rail, and I used my buddy's Bridgeport to do the manifold and fuel rail.
He's had some issues with the MS box but they took care of it for him. He's getting it tuned now to where he is very happy with it.
[Re: MuuMuu101]
#2358661
08/23/17 05:20 PM
08/23/17 05:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They didn't spend crap on developing the 3.9, go read the story at Allpar, it will answer your questions.
