Re: MAX WHEEL AND TIRE COMBO USING INBOARD SPRING KIT???
[Re: firefighter3931]
#1037412
07/24/11 03:44 PM
07/24/11 03:44 PM
BradH
Brad H also runs CalTracs and 295/65 M/T's and 60 fts in the 1.40's
I run the smaller 275/60R15s, CalTracs, std-height mono springs, older 5-way adjustable Rancho shocks, small-block t-bars, QA1-R front shocks, and the front set up for 5+" travel from static ride height. The car was pulling consistent 1.45-1.46 60-fts. the last couple of times the car was run in 2009, but hasn't been back to the track since then.
Also, I don't like the jacked-up look and my car sits fairly low & level as you can see here.
[Re: BradH]
#1037413
07/24/11 05:40 PM
07/24/11 05:40 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
No snubber ever used with Caltrac monoleafs and bars. Get the rear end out of the air. Superstock springs have a tendency to ride high. I tried these when first putting the car together and quickly went to the Calracs. Car sits low and works great.
[Re: Labratt]
#1037415
07/24/11 10:01 PM
07/24/11 10:01 PM
Posts: 4,066 Mo.
racerx
Mo.
Fellers...I think you're onto something! Mike(P-Body)made a note of the same exact thing! The rear shackles are in a "neautral" position when the chassis is loaded!...straight up and down. Maybe the total length of the A-Body spring is throwing the angle off whack! I know the shackle should be at a 30 degree angle forward,for best results! What is the fix? Drill new mounting holes for the shackles...or just get new SS springs?...if so,which weight-rated ones? Thanks Angelo,and Ron!...and Raff,for your help! BTW...Angelo,haven't run my pinion snubber in years. Are you running one on the Satellite???
I know the shackle should be at a 30 degree angle forward,for best results!it's been a while sense i'v run the ss spring but i thought that the rear shackle is supposed to be facein the rear at your loaded settings(if that makes any sense)
[Re: formula S]
#1037416
07/24/11 10:21 PM
07/24/11 10:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Two places to check, 1st make sure you have enough front end travel 5 to 6 inches, you may have to lower the front end to achieve this. 2nd make sure your rear shocks arent to short, because if they are as the chassis rises it will take the rear end with it and unload the tire causing it to bounce, resulting in poor 60ft times. Plenty of guys are using the same parts that you are, I think you just have some tuning to do good luck
He has a couple of problems... the tire size he wants to run(on the street) is just clearing and he has the body up so they clear... being that the body is up it has less travel in the shocks(extension)... and the rear shackle angle is wrong.... looking under there today if he wanted to move the springs in-board it wount do a bit of good, he has about 5/8" clearance to the inner wheel well... the vid he showed earlier had his shock settings on 5 and it topped out the shocks
[Re: Labratt]
#1037418
07/25/11 12:54 AM
07/25/11 12:54 AM
MR_P_BODY
Kerry...I may have misspoken! It might be 30 degrees,angled to the rear! I'll have to check my MP Chassis Manual! Meanwhile...can someone chime in? Thanks!
The top angles to the front
[Re: 10secGTX]
#1037421
07/25/11 04:59 AM
07/25/11 04:59 AM
Posts: 793 Utah
topbrent
Utah
My vote for cal tracs.... and mono's and getting the correct rim,
+1
[Re: topbrent]
#1037422
07/25/11 09:12 AM
07/25/11 09:12 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Randy give me a call so I don't have to type all morning. Jake
JAKES AUTOMOTIVE
[Re: Labratt]
#1037428
07/25/11 09:12 PM
07/25/11 09:12 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
Thanks,guys! In actuality,the front spring mounting bolt is in the TOP hole! If I drop it down to the BOTTOM hole,will that lower the rear end ride heighth? I talked to Gary Jacob(Jake68)today,and he said that it's common with the B-Body cars with A-Body springs, to drill a new rear spring mount hole forward of the existing mounting hole...to correct the rear shackle angle! Please give me your opinions on this! THANKS! Randy B.
Listen to Gary, he's right on!
[Re: Labratt]
#1037430
07/26/11 12:42 AM
07/26/11 12:42 AM
MR_P_BODY
I think we talked about the shackle angle the other day
