CUDA headlight fittment #103629
08/12/08 07:40 AM
08/12/08 07:40 AM
, PA
sleepyhead416 Offline OP
, PA
Anyone have trouble getting their grille back in around the headlights mine are thight on both (tight fit towards outside) of fender. The only way I see to fix this is cut spotwelds off of headlight buckets and center them.Then weld em back in place. OH factory fenders
Re: CUDA headlight fittment [Re: sleepyhead416] #103630
08/12/08 09:09 AM
08/12/08 09:09 AM
cataclysm80 Offline
cataclysm80  Offline
I had that problem on my passenger side fender. It had been hit before (minor/mainly bumper), and it was repaired off the car so full grill wasn't test fit, only the headlight bezel. Didn't discover this till after paint. Rather than rework the painted fender, we moved the headlight bucket as you suggested.
Since your having the problem on both sides though, is there any way you could just adjust the front of your fenders outward?
Tav
Re: CUDA headlight fittment [Re: cataclysm80] #103631
08/12/08 10:30 AM
08/12/08 10:30 AM
, PA
, PA
Can't move fender out. Cut 3 of the 4 spot welds pulled it down & to inside respotted brackets good to go MUCH MUCH better.
