Re: 160 thermostat-vs-180 thermostat & no cold weather driv
[Re: stumpy]
#1035848
07/19/11 09:12 PM
07/19/11 09:12 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: 63stabamatic]
#1035851
07/20/11 08:43 AM
07/20/11 08:43 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I saw a chart that showed how engine wear reduced exponentially as engine temp comes up, with wear being almost nil at 180-185.
**Photobucket sucks**
[Re: 63stabamatic]
#1035852
07/20/11 09:30 AM
07/20/11 09:30 AM
Posts: 5,278 San Jose, California
DennisH
Vacation
Vacation
I agree, 160 is too cold. I run a high flow 180 degree stat in my stock 69GTX 440 with A/C.
180 Napa superstat. Minimum.
[Re: DennisH ]
#1035853
07/20/11 10:26 AM
07/20/11 10:26 AM
Posts: 1,465 Carson City, NV
babarracuda
Carson City, NV
Back in the 60-70's, we ran 160 thermostats so it wouldn't overheat on hot days. If your radiator is adeqate, 180 is by far better. 160 only helps with an undersized radiator, and then only until there are really hot days. If you need a 160 thermostat, don't cruise on hot night or take trips more than 60 miles. Been there, done that, got the Tshirt.
[Re: A12]
#1035854
07/20/11 10:53 AM
07/20/11 10:53 AM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
If it's cold weather(definition of cold ?) 180 is the way to go but in hot weather...85 on up....I run a 160 as it will heat quickly to 160...open and allow the engine to "potentially" run cooler than a 180. Old cars need to run cool...unlike the new cars today that are designed for higher temps. My silverado runs a steady 210 when warm..I wouldn't run My Bee very long at 210. AND as far as burning bad stuff off...would Your finger be hurt any less in a vat of 180 oil or 160 oil ?
In the 50's/60's we'd run no thermostat in summer. Why...keep the old iron cool...High temps...210 plus is not good...I've run a 160 for decades and I'll wager I get more miles out of a block than higher temp stats. My experience of driving for over 45 years.
Note...not to scare you but a 180 in a car with a good cooling system will NOT hurt anything..it's just with a 180...engines tend to run 190 plus..then cool..then heat...where a 160 will keep them under 180 and that's what I prefer
[Re: babarracuda]
#1035855
07/20/11 10:55 AM
07/20/11 10:55 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
A stat can't keep a vehicle from over heating. It was another myth. A stat cannot regulate temps above the stat rating. Once it is open it open whether it is a 160 or a 190. Just like the thermostat in your house cannot regulate the temperature above what the thermostat is set at on a hot day. If you have your stat set a \t 68 and the sun wants to up teh temp to 90 there is no way that the stat can regulate that. (AC equiped house not withstanding)
[Re: dogdays]
#1035858
07/20/11 01:50 PM
07/20/11 01:50 PM
70Cuda383
Marysville, O-H-I-O
true, max power vs longevity. it's a trade off.
as it always is.
wanna make 8,000 hp? well, consider yourself lucky if it stays together for 1/2 mile.
want to run 200K miles on one rebuild? then you're not going to run a massive cam with aggressive ramps that require insane spring pressures
on the engine dyno, we made max power by doing 4 back to back pulls to get the oil temp up as high as we could. it was at 185 degrees.
then we dumped the hot water out, and cycled in cold water until the water was coming out at 110 degrees.
then made another pull, and picked up 15 hp over the other pulls we had been making.
but...when are you ever going to be able to duplicate that on the street?
[Re: MoparforLife]
#1035860
07/20/11 02:50 PM
07/20/11 02:50 PM
terzmo
Pendleton NY
I agree as if the water temp is over 160..the stat is going to open and won't close till under 160. A stat will heat up a car faster than a non stat system as it won't allow flow through the rad untill the water temp is over the stat rating. With no stat..you get "potential" max cooling all the time as the is no water obstruction. Even an open stat reduces the opening,thus reducing water flow.
[Re: A12]
#1035862
07/21/11 01:50 PM
07/21/11 01:50 PM
Posts: 21,498 N.E. OHIO, USA
A12
N.E. OHIO, USA
[Re: A12]
#1035863
07/21/11 01:50 PM
07/21/11 01:50 PM
MoparforLife
Upper Midwest
FWIW: Yesterday with a 160 standard flow thermostat, outside/ambient temps in the mid 90's (F) and cruising on the Ohio Turnpike at 70 mph. Sunday with similar conditions but a little cooler out the temp gauge needle was right on the next to the last line and the car puked coolant two minutes after I shut the engine off at a local cruise . just FYI and I have no clue on a 160 versus a 180 thermostat????
MikeR
That is why they came out with burp tanks. wasn't that you were necessarily overheating but that the coolant quit circulating and pressure built up.
[Re: az426john]
#1035865
07/21/11 02:29 PM
07/21/11 02:29 PM
A12
N.E. OHIO, USA
You can't compensate for a cooling system that is at its maximum efficiency by using a colder thermostat.
In the Arizona desert many of us use triple core radiators with 3/8" tubes on 3/8" centers. It is just a simple fact of life that anything less is marginal and will probably fail just when you don't want it to.
Understand and agree with what you and others are saying about that but why have differant heat rating thermostats at all if there is no difference between a 160, 180, 195 or why even have a thermostat if they have no affect on engine running temp or cooling? Would I be better to get an aluminum multi core radiator and electric fan and not run a thermostat in a system like that?
[Re: A12]
#1035869
07/21/11 04:27 PM
07/21/11 04:27 PM
Posts: 32,918 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
The different stats have an effect on what the lowest temp will be not the highest. A 160 will open at 160 and a 195 won't open until the engine hits 195. Most street engines need a 180-185 stat to operate their best. Race engines do better at 160. A 180 stat will make the engine run at least 180 but won't keep it down at 180. A 160 will make the engine run 160 but again not keep it at 160. The high temps are controlled by flow and the engine and raditors ability to dispell heat.
