8 3/4" pinion angle question #1033198
07/15/11 09:37 PM
07/15/11 09:37 PM
Tri-Cities, Washington
V
VITC_GTX Online content OP
VITC_GTX  Online Content OP
V
Need to shorten a C body housing for an A body. Also need to move perches.
When I get ready to tack on the perches I wanted to get 5 degrees up pinion angle when the perches are level. Can I just measure from the face of the housing or do I have to install the pumpkin (is the pumpkin mounting face perpendicular to the pinion shaft)?
Re: 8 3/4" pinion angle question [Re: VITC_GTX] #1033199
07/19/11 01:16 AM
07/19/11 01:16 AM
V
V
Re: 8 3/4" pinion angle question [Re: VITC_GTX] #1033200
07/19/11 01:34 AM
07/19/11 01:34 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Use the face, it should be fine.
Re: 8 3/4" pinion angle question [Re: RobX4406] #1033201
07/19/11 01:46 AM
07/19/11 01:46 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I am wondering why you want 5* up pinion angle.
Raul
Re: 8 3/4" pinion angle question [Re: Aspen7695] #1033202
07/19/11 01:50 AM
07/19/11 01:50 AM
V
V
5 degrees up was suggested by Cass (Dr. Diff).
Re: 8 3/4" pinion angle question [Re: Aspen7695] #1033203
07/19/11 01:50 AM
07/19/11 01:50 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Raul
I wonder to.. optimum is 2 - 4 down at ride height....
I am truckless..
Re: 8 3/4" pinion angle question [Re: 340SHORTY] #1033204
07/19/11 01:58 AM
07/19/11 01:58 AM
V
V
Raul
Cass told me that with the rearend out and the perches on a level surface the pinion should be 5 degrees up. Once installed I imagine the angle with be within acceptable limits
Re: 8 3/4" pinion angle question [Re: 340SHORTY] #1033205
07/19/11 04:12 AM
07/19/11 04:12 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A-body pinion-to-perch angle is 5 degrees up. This is NOT pinion angle because the springs are not parallel to the transmission.
If the rest of the drivetrain angles are stock, these dimensions will yield a 2 degree negative pinion angle once the housing is installed.
Re: 8 3/4" pinion angle question [Re: DoctorDiff] #1033206
07/19/11 04:31 PM
07/19/11 04:31 PM
V
V
Thanks for the clarification Cass. Sorry for not being clear with the information you provided.
