Part # for Centerforce clutch 360 Duster? Found deal!!
#1033184
07/15/11 09:16 PM
07/15/11 09:16 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Hey guys, does anyone know the right part # for a dual friction clutch kit for my car? I keep coming up with a couple different numbers.
I have a 72 Duster that I'm droping in a 1974 360 with an A833 cast iron tranny, it has a 10.5" clutch now, but when I look up clutch kits for my car I get a 10.4 and an 11", both saying they fit a 360. Looking to buy asap so I want to make sure I get the right one, and I know there quite popular around here. Thanks
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: Anyone know # for Centerforce clutch for 360 Duster?
[Re: 440Satellite]
#1033185
07/15/11 09:48 PM
07/15/11 09:48 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
My 1974 360 Duster used what I believe they called a scaloped clutch, which basically had a 11 inch disc with a special pressure plate that bolted to the 10 1/2 inch pattern flywheel. The truck 360 used an 11 inch clutch and pressure plate, not the car. You should use the 10 1/2 inch pattern flywheel, and the correct bellhousing that goes with it. Then you can get either a special scalloped clutch, or the 10 1/2 inch clutch. Call Brewers, or look up his site , and he will get you the proper clutch for your needs !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#1033186
07/15/11 10:01 PM
07/15/11 10:01 PM
440Satellite
super gas
super gas
Hazlet, NJ
Thanks, I think I found the right one, does this sound right?
Centerforce DF269675
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#1033187
07/15/11 10:14 PM
07/15/11 10:14 PM
doctor_mopar
Slidell, La.
Yes, That number will fit. I have one here now to go in a 340 Duster, and I put the same model in a 440-6 Cuda( with 23 spline trans ) I just removed the over center spring on the clutch pedal, and it works great !
[Re: doctor_mopar]
#1033188
07/15/11 10:28 PM
07/15/11 10:28 PM
440Satellite
super gas
super gas
Hazlet, NJ
Excellent, thanks alot, found a good deal on it so I want to snatch it up!!!
Butch
1972 Duster
318 4 speed
[Re: 440Satellite]
#1033189
07/15/11 11:07 PM
07/15/11 11:07 PM
440Satellite
super gas
super gas
Hazlet, NJ
Nice just picked it up brand new for $237 with free shipping, cant beat that with a stick!!!!!
Thanks again
Butch
1972 Duster
318 4 speed
