Which Assembly Lube for Distributer Gear? #1028424
07/08/11 03:51 PM
07/08/11 03:51 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I've got some Lucas assembly lube that is green and kind of runny and then I've got some Sta-Lube that is black and thick. That's all I could find at the auto parts stores around here. Both say they contain Moly and Zinc. The engine builder used some thick red stuff on the cam. Which should I use or does it matter? Thanks!
Re: Which Assembly Lube for Distributer Gear? [Re: 67Satty] #1028425
07/08/11 03:54 PM
07/08/11 03:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd use the Lucas
Re: Which Assembly Lube for Distributer Gear? [Re: 67Satty] #1028426
07/08/11 05:19 PM
07/08/11 05:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Motor oil works just fine
Rich H.
Esse Quam Videri
Re: Which Assembly Lube for Distributer Gear? [Re: ZIPPY] #1028427
07/08/11 05:24 PM
07/08/11 05:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use the white Lubra Plate.Used it at work also since the 80s.I use it on the ends on rockers also.Rocky
Chrysler Firepower
Re: Which Assembly Lube for Distributer Gear? [Re: therocks] #1028428
07/08/11 06:42 PM
07/08/11 06:42 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
White grease (not spray, mind you.)
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
