71 B Body Build Sheet Questions
#102714
08/11/08 01:32 AM
08/11/08 01:32 AM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
I've decoded most of my build sheet, but need some info from the experts here:
1) Below the "11" row (the last row), there is a stamped #13 followed by "Oil Unit." What does this mean?
2) What do the W11 "Deluxe 14" Wheel Covers" look like? Can someone post a pic?
3) What was the code for the rear window defroster. My car definitely came with one from the factory, but I don't see it listed on the build sheet. The column is there ("H" on row "6"), but there are no markings there.
4) Where do the M25 "Wide Sill Mouldings" go, on the top of the door? Looks like my car did not come with them if they go on top of the door, but the Broadcast Sheet says it did.
'71 SSP - SOLD!
Re: 71 B Body Build Sheet Questions
[Re: Mobarge]
#102715
08/16/08 05:28 PM
08/16/08 05:28 PM
Posts: 337 CT, USA
RM23V1
CT, USA
1) Notation for oil pressure gauge and sending unit. 2) Click here for the wheel cover pic (it's the one in the top left corner) 3) The defogger code was H31. If it's not on your sheet, like in the picture attached, it may have been added later. 4) M25 refers to the rocker panel moldings (below the doors) so I'm assuming you have a GTX, since they weren't available on Road Runners.
[Re: RM23V1]
#102716
08/18/08 08:30 AM
08/18/08 08:30 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
They did come on SSP's
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#102717
08/18/08 11:57 AM
08/18/08 11:57 AM
Mobarge
Los Angeles, CA
Yes, now I remember the car actually DID come with the rocker mouldings. I removed them, and they're on someone's GTX now.
'71 SSP - SOLD!
[Re: moparmarks]
#102718
08/18/08 12:05 PM
08/18/08 12:05 PM
moparmarks
Should add that the SSP moldings were smooth verses the ribbed ones on the GTX.
