Is a .50 volt drop form alt to battery in trunk ok??? #1026110
07/04/11 10:43 PM
07/04/11 10:43 PM
IN
Dartman928 Offline OP
IN
Just got the car running on sat with the new alt. and took some readings. I have .50 volt drop from the alt. to the battery in the trunk. Wanted to make sure everything is ok
Re: Is a .50 volt drop form alt to battery in trunk ok??? [Re: Dartman928] #1026111
07/04/11 10:49 PM
07/04/11 10:49 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If the battery is fully charged to maximum capacity you will not see this. But, that rarely is the case. So yes the drop is normal. Your battery is a resister and the wire feeding from the alternator has some resistance too. The larger the wire you run and the better the contacts are the less drop. But, you will always have something if the alternator is indeed charging.
Leon
Re: Is a .50 volt drop form alt to battery in trunk ok??? [Re: Leon441] #1026112
07/04/11 11:47 PM
07/04/11 11:47 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Leon
Is that with the starter engaged turning the engine over?
Re: Is a .50 volt drop form alt to battery in trunk ok??? [Re: Leon441] #1026113
07/05/11 12:30 AM
07/05/11 12:30 AM
IN
IN
Leon
Thanks Leon
I run a 6 gauge from the alt. to the master power switch and 1/0 welding wire from the battery to the switch to the for solenoid under the dash. I just want to make sure I am getting everything I am supposed to from the alt. to the battery.
Thank you
