1970 cuda wiring harness #1022844
06/29/11 05:47 PM
06/29/11 05:47 PM
kentucky
jstewart Offline OP
jstewart  Offline OP
kentucky
does anyone have a picture of the wiring diagram for the dash harness of a '70 barracuda? any help would be appreciated
Re: 1970 cuda wiring harness [Re: jstewart] #1022845
06/29/11 07:56 PM
06/29/11 07:56 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Re: 1970 cuda wiring harness [Re: twodoorpost] #1022846
06/30/11 01:33 PM
06/30/11 01:33 PM
kentucky
jstewart Offline OP
jstewart  Offline OP
kentucky
thank, those were the same ones that i was using but my printer cut some of it off, im puting all new wiring harnesses in the car and was wondering if anybody knew where i could find a list of all the ligh bulbs i would need, for the dash lights, markers, tails etc?
Re: 1970 cuda wiring harness [Re: jstewart] #1022847
06/30/11 02:25 PM
06/30/11 02:25 PM
middle of the country
aar1 Offline
aar1  Offline
Owners manual?
Re: 1970 cuda wiring harness [Re: aar1] #1022848
07/01/11 03:08 PM
07/01/11 03:08 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Print in landscape mode and use the fit to page setting in the print menu.
Re: 1970 cuda wiring harness [Re: Snoopy] #1022849
07/01/11 03:09 PM
07/01/11 03:09 PM
Snoopy Offline
Snoopy  Offline
2
Re: 1970 cuda wiring harness [Re: aar1] #1022850
07/02/11 02:43 AM
07/02/11 02:43 AM
Northern California
redwrydr Offline
redwrydr  Offline
Northern California
Page 8-120 in the service manual....but be careful not to go out and get every bulb listed, if you don't have the light group you won't need some of those listed on that page....ask me how I know...
Re: 1970 cuda wiring harness [Re: redwrydr] #1022851
07/02/11 04:07 AM
07/02/11 04:07 AM
Snoopy Offline
Snoopy  Offline
Bulbs
Re: 1970 cuda wiring harness [Re: Snoopy] #1022852
07/09/11 11:02 AM
07/09/11 11:02 AM
kentucky
jstewart Offline OP
jstewart  Offline OP
kentucky
thanks, once i got working on the dash harness it was all pretty straight foward,and thanks for the light bulb numbers my service manual was probably tossed in the 70's
Re: 1970 cuda wiring harness [Re: jstewart] #1022853
08/17/11 01:44 PM
08/17/11 01:44 PM
kentucky
jstewart Offline OP
jstewart  Offline OP
kentucky
can anyont side marker lights use? i don't see it on the list, and what would cause both of the turn signal indicators on the dash to stay on whenever my headlights are on?
Re: 1970 cuda wiring harness [Re: jstewart] #1022854
08/17/11 02:00 PM
08/17/11 02:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1895's
most likely - bad grounds for the running light assemblies
OR
least likely - bad grounds for the dash frame itself
