1968 B029 and LO23 SS A-body differences #102101
08/09/08 08:49 PM
08/09/08 08:49 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
If you cant buy one... build one. What are the modifications Hurst made to these cars. Please post pictures of what you have and know if possible.
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102102
08/09/08 08:58 PM
08/09/08 08:58 PM
JRepucci Offline OP
JRepucci  Offline OP
Things I know...
Thin Glass in doors and quarters
rear glass fixed(no regulators)
front glass secured by straps made of seat belt material
door mirror delete
heater delete(passenger side vent box)
A-100 seats and aluminum brackets.
Fiber Glass fenders and hood
acid dipped doors
acid dipped bumpers
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102103
08/09/08 09:04 PM
08/09/08 09:04 PM
JRepucci Offline OP
JRepucci  Offline OP
relocated master cylinder and modified brake lines
passenger shock tower SMASHED IN!
HEMI K-frame and and 1/2 inch spacers
manual steering
manual disk brakes
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102104
08/09/08 09:07 PM
08/09/08 09:07 PM
JRepucci Offline OP
JRepucci  Offline OP
Stewart Warner tach
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102105
08/09/08 09:35 PM
08/09/08 09:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There's a soft spiral bound book that is very very helpful on all of this. Must have for what you are doing. I think by Jim Schild???
-have special large bolt pattern KH disk from the A-body rallye and trans am program (Tarrozzi was a member of Team Starfish)
-had mufflers/resonators with turn downs
Re: 1968 B029 and LO23 SS A-body differences [Re: autoxcuda] #102106
08/09/08 09:38 PM
08/09/08 09:38 PM
JRepucci Offline OP
JRepucci  Offline OP
Where can you buy the book?
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102107
08/09/08 09:44 PM
08/09/08 09:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've just seen the book. I think amazon or something probably. Just search Super Stock Dart book or something. Shouldn't take you long.
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102108
08/09/08 09:58 PM
08/09/08 09:58 PM
JRepucci Offline OP
JRepucci  Offline OP
1968 Dart & Barracuda Hemi S/S Authenticity Guide
found it at Mancini Racing. $18.95
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102109
08/10/08 08:45 AM
08/10/08 08:45 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: 1968 B029 and LO23 SS A-body differences [Re: AdamR] #102110
08/10/08 02:05 PM
08/10/08 02:05 PM
JRepucci Offline OP
JRepucci  Offline OP
Were the barracudas made from a Formula S body?
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102111
08/10/08 02:42 PM
08/10/08 02:42 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I believe they were 383-s to begin with.
Re: 1968 B029 and LO23 SS A-body differences [Re: JRepucci] #102112
08/10/08 02:52 PM
08/10/08 02:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've heard that they were 383 cars pulled off the line. That would make them destined to be GTS/"S" cars. But it may be more involed than that.
Both got convertible frame bracing at least. I think that is more than what a 383 4spd got?? So I don't know if you could consider that a Formula S or GTS body or a "S"/GTS plus.
Darts have 270 interior trim. Most all the things that made a Formula S were either gutted/not used or not applicable to a Super Stock.
Only thing I wonder on the Barracuda is whether the Super Stocks had rear valences with dual exhaust cutouts??? All and only "S"'s got dual exhausts in 1968.
That book will help/answer these questions. Or others on this list. I don't know those S/S much, but more familar with the Formula S and GTS cars.
Re: 1968 B029 and LO23 SS A-body differences [Re: autoxcuda] #102113
08/10/08 06:16 PM
08/10/08 06:16 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The book is a good read but it doesnt have a lot of "usefull" info on building a car the way they came out of the Hurst factory. Still worth the $20 though.
Re: 1968 B029 and LO23 SS A-body differences [Re: autoxcuda] #102114
08/10/08 08:04 PM
08/10/08 08:04 PM
JRepucci Offline OP
JRepucci  Offline OP
autox,
The reason for the question was the rear valance cutout idea. Did the or didn't they... I do believe that they had the torque boxes....
I have found a real Formula S car that I might use for the project...its a really nice, low mileage car...numbers match, buildsheet, original paint car:) anyone want to buy some parts?
